12-27-2018, 08:23 AM
Dennawayne
2021 22' Caravel
Clarkdale
Locked inside my Airstream at Walmart
Well this is an interesting thing that happened to my wife and I on the first day out of the second leg of our travels across the US. We had been in Washington State visiting our kids and grandchildren. We pull into Walmart at Hood river about 5:30 pm and set up for a little shopping and get something to eat. We returned about 7 pm. On entering I closed the door. I heard the familiar 1st click and with grasping the handle firmly I gave the final tug to secure the door and off I went. The entire black entry handle in my hand became completely detached from the door and momemtemly sending towards the street side interior bulkhead. Whoa daddy! My wife and I are now locked in our 30’ 2015 International Signature in Walmart. I am confident we will not starve here but I am a tad upset that I was almost launched through a window holding madly on to a door handle. As if that might save me. Mind you I have tools but....they are in the pickup truck. My first thought was I need to get out of here and then open the door and then figure out how this thing works.
I open the window which was fortunately did not rescreened as of yet and I pop my head out and yell, “hey buddy can you give me a hand?” Hey buddy! Heeeeyyyyy budddy. Buddy. Buddy. I’m sure he hears or sees me as he continues checking over his fifth wheel about 75 yards away. Never looks up. Never hears me. Never glances over. I’m still locked in the AS. Well honey I’m going in. I’ll lower myself to the ground through the window, still spry at 66 but geez I wasn’t expecting this!
Long story short. I was able to get on line and to the Forum, this has happened before and yes you only need a small straight slot screwdriver to free yourself from the grips of your AS. My post is how to permanently fix that stupidly designed swagged handle. It in my opinion is designed to fail a nut is swagged not welded to th handle. Of course they are of dissimilar metals but they could hatapped the handle and ran a a threaded stew into the handle to secure the plate. Don’t worry I have pictures.
That handle gets abused and according to many threads it’s happened quite a bit. Jackson Center they just replace the whole door latch mechanism, that’s a lot of mulla. This seemed an easy fix so just bought a tap with a screw to fit the threads and a locking washer and voila, I fixed the newel post honey.
12-27-2018, 08:32 AM
2018 16' Sport
Austin
Sorry to hear this. We had something similar happen to us with out 2018 16RB. We were locked inside at Garner State Park. Like you, my tools were outside, however, I did have a leatherman tool inside the camper. The problem for us was that the screen door frame blocked a couple of the screws to the door latch mechanism. I was only able to take out one screw. After about 30 minutes with the leatherman and a flashlight I was able to figure out how to release the latch mechanism after prying only one side of the mechanism open by about a half inch.
Of course this was a minor problem compared to the leaky door on a brand new Airstream that took months to fix. We think. Maybe. But that's another story.
2011 Chevy Silverado 1500 4X4
2018 16-RB Sport - portable solar and Honda generators
2015 T@B Max-U Outback
K5BRY
12-27-2018, 08:39 AM
1958 18' "Footer"
Idyllwild
an easy fix....buy vintage!
12-27-2018, 08:45 AM
Tampa
I'm planning to add this and stop pulling on the handle.
Kudos to the forum member who posted this.
12-27-2018, 08:48 AM
1976 31' Sovereign
Oswego
It can happen w/vintage AS to. It happened to me at home. Simple fix, screw driver set kept in AS, removed screen opened window reached out pulled out side handle door opened. Found roll pin broken in lock set, replaced now fixed. Only prob have to remove lock set from door, dismantle insert new roll pin, good as new.
12-27-2018, 09:00 AM
2016 25' Flying Cloud
Venice
Similar incident happen to me last summer while camped at Penn Wood Airstream Park in Pa. However, my handle did not come off but was loose & wound not reopen from the inside. After exiting through the window in pouring rain, I open the door from the outside & discovered the problem. On that black plate there are 3 little screws that hold it tight to the door. My screws were loose & one completely out causing the plate & lock mechanism to shift & un-engage. From the outside I reset the handle & plate with the three screws. Now I check them screws ever day when the trailer is in use.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
12-27-2018, 09:24 AM
1978 31' Excella 500
Barrie
, Ontario
Don't buy anything made by Thor! That's what's wrong with the new AS Thor bought them in 2002 and they have gone downhill ever since!
12-27-2018, 09:48 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
You got to learn two things. 1) where the fire escape window was located & 2) Loctite Blue 242 works wonderfully when applied to screw threads.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
12-27-2018, 09:51 AM
2013 25' FB International
Littleton
Needless to say, before next time happens carry a scaled down emergency toolset INSIDE your trailer. Not hard to find a place to store some emergency tools.
12-27-2018, 10:01 AM
2017 19' International
Tallahassee
I got locked in (in my yard, not at Wally World). Handle didn't come off, but locked in, nonetheless.
Twenty minutes of jiggle got it to open.
If I had had a screwdriver handy, what could I have done?
12-27-2018, 10:02 AM
2007 27' Safari FB SE
La Pine
, Oregon
WIndow screens
This brings up another point - the window screens. Shortly after I bought my AS, I went out for something or other and the door locked behind me. (The locking "knob" is too close to the handle and being spring loaded, too easily bumped, which locks the door.)
It was @ 10:00 PM and no one was around. Worst of all, my two dogs were locked inside the AS. I finally trudged over to a neighbors and woke them (they weren't too happy) to get a screw driver (I had a set of tools, but they were locked in my truck and the keys were in the AS).
I was able to pry open the lounge window with the screw driver and pushed out the screen so I could crawl into the AS and unlock the door. I haven't replaced that screen yet (it's been about a year now).
So why doesn't someone make a replaceable screen for the AS windows (the "escape" window in the bedroom also requires you to push out the screen to make an exit)?
It would be nice if someone made a screen with Velcro attachments that would allow you to remove the screens without the need to "permanently" re-attach them.
12-27-2018, 10:05 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
oop's...😳 that happened in 1980
I secured our handle with 3M 5200....8yrs ago,SFSG
12-27-2018, 10:09 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Did you take pictures as you flew across the Airstream?
Sorry but I think we've all been in a similar situation. Mine was once with the black tank dump valve handle....
12-27-2018, 10:35 AM
Same thing happened to us. Except I had to go out the emergency exit and go around to open the door. Airstream replaced the lock and screen. Airstream is aware of it but has not done anything to fix the problem.
When they were repairing the lock I was able to look at the mechanism and see how to manipulate the post to open with small screw driver. This would be a nice procedure for the owners manual.
12-27-2018, 10:36 AM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Having been trapped inside both a 1967 and a 1983, I'm not sure that works.
It does make finding parts for the locks more of a challenge, though.
Vaughan
12-27-2018, 10:44 AM
Overland Adventurer
2009 34' Panamerica
Telluride
FYI, Thor has owned Airstream since the third fiscal quarter, 1980.
12-27-2018, 11:40 AM
2014 23' International
Hurst
12-27-2018, 11:52 AM
2014 31' Classic
2015 23' International
Apache Junction
I have to use a caribeaner for my keys so they are either in the lock, my hand or fastened to my belt loop. Short term memory being what it is, fastening an emergency push device by the door in easy view will possibly trigger the thought "I use that to open a stuck lock"
Some us with silver or no hair may remember Betty Furness and the Play House of Stars where Westinghouse advertised the "quality goes in before the name goes on". When I saw the name missing on the back of our brand new 2015 23D International Serenity.....
I was warned and, yes, there were major issues.
12-27-2018, 12:18 PM
2022 20' Basecamp
1968 17' Caravel
Los Osos
It certainly can happen with a vintage. We were locked in our 68 Caravel a couple of times.
Solution...we found an NOS Bargman door set to replace the original. Door sets need periodic lubrication and reconditioning if they have been in service for more than a few years.
Also, since Airstreams of a certain age lack a formal escape window, keep something close that will easily smash the rear or front windows.
12-27-2018, 02:01 PM
2019 27' Tommy Bahama
London
, Ontario
Hi Bev
Thor was actually formed so Wade Thomson and Peter Orthwein could purchase Airstream from Beatrice foods in 1981. Not sure where you got the 2002 date.
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
