01-18-2015, 05:24 AM
ottawa (greely)
, Ontario
Did airstream change back to fiberglass insulation
There has been some discussion on this forum that some airstream owners have seen pink fiberglass insulation on there late model 2015 airstreams, I was told that airstream has gone to a brown insulation in there 2015 models and I was at the factory in March 2014 and they were using the brown insulation,mine is a 2015 and has the brown insulation ,built in June 2014 , some have said they maybe have switched back to the old fiberglass insulation, is this true and for what reasons ,lack of supplies of the new insulation? Or is there a problem with the new brown insulation.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
01-18-2015, 07:37 AM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
2015 30' Bunk. At the time I did not think much about it but I went back to see if any of my RV550 installation pictures showed the pink fiberglass. Here is the only shot I could find showing what I removed from the walls around the old water heater after removed. It is the same as the small tuffs I have seen coming from between some of the interior aluminum panels.
What does the brown stuff look like?
01-18-2015, 08:09 AM
Curtis Wright
Eyren Haven
, South Jersey
Fiberglass is fiberglass. Owens has a copyright/patent on the color pink.
01-18-2015, 06:59 PM
2023 30' Globetrotter
Pleasanton
We just did the factory tour last fall and they were touting on the tour about the insulation and how it allows anyone to install it which used to be an issue for the pink stuff. Maybe it's not fiberglass anymore? I wasn't critiquing the guide, so wasn't hanging on his every word, but I seem to recall him starting that is recycled?
01-18-2015, 07:48 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Brown insulation would suggest mineral wool, rather than fibreglass. Such as that made by Roxul. There certainly is no shortage but it is slightly more expensive. It's also a better product than fibreglass. Mineral wool is hydrophobic, so it isn't impacted by moisture like fibreglass is. Hopefully Airstream has abandon the use of fibreglass in its production.
North Vancouver, BC
01-19-2015, 06:50 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I have seen fibreglass insulation in white, brown, yellow, blue and pink...
I agree mineral wool would be a better choice, and there are even better choices out there, but it comes down to cost. "Cost" includes the cost of the materials as well the labor to install it. Things like spray foam takes expensive equipment, personal protective equipment and some skill to install.
Aaron
WBCCI #XXXX AIR #2495
01-19-2015, 11:33 AM
2013 30' Classic
Greenwood
, Mississippi
Didn't they say on the factory tour that the insulation was recycled denim? Or was it recycled newspapers? Recycled something or other- I thought blue jeans- it is kind of a brownish grayish color-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
01-19-2015, 11:56 AM
Seattle
It's Eco-Batt, a fiberglass insulation made from recycled glass.
01-19-2015, 01:09 PM
2013 30' Classic
Greenwood
, Mississippi
I think the new recycled glass insulation is part of the "going green" or "certified green" effort-
TAC #MS-10
Airforums #70955
01-19-2015, 02:27 PM
2002 19' Bambi
Lafayette
If you look on the website for EcoBatt, you will find that it is made from recycled glass plus sand. Presumably the sand mentioned is quartz sand, the raw material for glass which is not partly from recycled glass. Rock wool is made from melted rocks of various types and is, essentially, volcanic glass.
The differences between the fibers in the pink stuff, the brown stuff, and rock wool are minor. The binding material which holds the batting together and the density of the batting can be very different. Also, they all will hold water like a sponge, so keeps those leaks under control!
Tim
01-19-2015, 03:04 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I've got the green sticker on my 2014 and I see pink insulation. For what that's worth.
2019 Ford Expedition Platinum
01-19-2015, 03:18 PM
ottawa (greely)
, Ontario
Here is a picture of the insulation discription in the 2014 airstream brochure.
Don
01-19-2015, 03:30 PM
ottawa (greely)
, Ontario
Here is a picture of the insulation from the insulation manufacture.
Don
01-19-2015, 03:31 PM
2020 Classic 33
Box Elder
, South Dakota
Yep that's the brown stuff at the factory. Thought they said wood based but guess not.
Which means someplace between an R-8 and an R-13 (2.5 to 3.5 inch thickness). Not bad...
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
01-20-2015, 10:59 AM
1972 25' Tradewind
North Vancouver
, British Columbia
Tim
Actually, fibreglass insulation will retain water. Mineral wool is hydrophobic and will not retain water and, therefore, makes for a better product in trailers or any situation where water might be present.
North Vancouver, BC
01-20-2015, 11:52 AM
2002 19' Bambi
Lafayette
I suspect that a hydrophobic character is much dependent on what is used to bind the fibers in the batting. According to Wikipedia, mineral wool is used in hydroponics:
"Mineral wool products can hold large quantities of water and air that aid root growth and nutrient uptake in hydroponics."
In other words, probably any glass-fiber product could be made nominally hydrophobic. Even so, with a dense batting, water will be retained.
Tim
01-20-2015, 02:31 PM
2015 16' Sport
Oakville
, Ontario
I don't care how water resistant it is, coat it, or heck keep the trailer sealed. Anything called "mineral-wool" sounds freaky to me, like asbestos freaky.
I'm suspicious of anything sprayed on or foamy, except as a sound deadener perhaps. Memories of urea-formaldehyde insulation spray, and I wonder what it's VOC venting, or if it's crumbling into dust.
I'd prefer new pink stuff to "recycled" eco tree hugger myself, only because my first thought is "recycled from what? medical waste?"
anyways it's ECObatt in the brochure, I'm sure the good folks at THOR wouldn't bait and switch me.
