09-15-2016, 01:28 PM
PSU1981
2015 27' Flying Cloud
Conroe
TPMS - sensors life
About to install a TPMS on our 2015 27FB FC. Read that each sensors transmit a wireless signal back every 7 Sec. How long do these sensors last? Do AS owners remove them while camping or when in storage to save the lives of the batteries?
09-15-2016, 01:33 PM
Biloxi
, Mississippi
Mine are about 3 years old. For the first year I never removed the sensors. After discussing with the TST rep I now remove them when at home. Still on the original batteries. I have a spare set for the day they crap out.
MICHAEL
09-15-2016, 01:45 PM
2015 25' FB Flying Cloud
Manassas
, Virginia
Hi AWCHIEF,
What was the reason for removing when home? I am under the impression that they go to sleep and wake up once moving. When I first turn on the display for my set I don't get a signal until we start moving - or was my timing just perfect from when turning on and getting connected.
Jeff
09-15-2016, 08:17 PM
Biloxi
, Mississippi
Originally Posted by AStreamNerds
Hi AWCHIEF,
Jeff
Best reason I know of, because I want too.
MICHAEL
09-15-2016, 09:08 PM
2016 26' Flying Cloud
Southlake
Any time they sense pressure they are working. It takes a few minutes for the dash unit to link with them. As soon as communications are established, you will get a readout. I don't think I needed it but I installed a remote transmitter and it blinks all the time, indicating the it is receiving signals from the sensors, even when parked.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
09-16-2016, 08:05 AM
Manassas
, Virginia
You said after discussing with TST rep you decided to...I thought maybe they gave you some insight. I was not questioning your actions.
09-16-2016, 08:24 AM
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
I have the internal Dill TPMS same as most cars. Will last 7-8 years. I highly recommend the Dill Trailer TPMS - no issues with valve stems or theft. Tire rack sells these $279 for everything. http://www.tirerack.com/tpms/detail....D=2179&ID=2179
09-16-2016, 12:05 PM
2013 30' Classic
Greenwood
, Mississippi
I think the life expectancy for the sensors is 5-7 years, about the same as the life of the tires.
When you get new tires, get new sensors.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-16-2016, 01:07 PM
2012 27' Flying Cloud
San Angelo
I have a set of pressure pro sensors that I put on a trailer in 2007. They finally failed this past February. That's about 9 years. Same quote of battery life, 5-7 years. I think each one cost about $40 to replace. They stay on the trailer all year long.
09-16-2016, 02:17 PM
Penokee
, Kansas
I found out that running higher tire pressure then needed it tends to rattle them apart ,,,where running lower pressure they tend to last longer.. lost track of the number I replaced in 50k miles and always fail when I ran max pressure.
09-16-2016, 03:23 PM
1992 29' Excella
Virginia Beach
, Virginia
I use the TST 507SE. I put them on my truck and AS. I won't go into details here as I'm doing this from my phone, bus let's say I have not found then that useful. PM me if you'd like to know more. That said watching the monitor on trips gives me peace of mind. The sensors are supposed to last about 5 years and the batteries are replaceable. I've had mine since February 2014. In July my monitor quite working right. The control buttons are not functioning. I just sent TST an email yesterday. I'll probably call them on Monday and see what my options are. I'm hoping they'll replace it.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
09-16-2016, 06:45 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Long story very short; It has cost me over $1200 to say:
Forget 'N'Vision' TPMs. I did get a partial refund, of $480 on one set, but the other is out of warranty.
I can only tell 'Engineering' to "go back to the drawing board"!
( having said that, I'm mindful of the saying:"You can always tell an Engineer, but you can't tell them anything!")
09-16-2016, 07:12 PM
Rich and Kat
Alexandria
Alexandria
, Virginia
Chief, did you epoxy them for easy on/off without the tool? Or do you use the tool each time?
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
09-17-2016, 06:45 AM
Biloxi
, Mississippi
Rich
Never heard of doing that. It would defeat the security requirement for using the tool.
MICHAEL
09-18-2016, 03:03 PM
Rich and Kat
Alexandria
Alexandria
, Virginia
Right on, Chief. The folks at TST told me that a number of their customers do it because it makes them much easier to remove, which thereby makes it less burdensome to remove, which ultimately increases security and battery life. Not that they were encouraging the practice, but that it wasn't a problem because their ultimately disposable units. I haven't done it to mine yet, but wondered what others that have, thought about the practice...
Rich
Rich
KB2ZMF Save
