05-23-2018, 08:05 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Wheel/Axle alignment
I was poking around under my new to me 2014 FC 23d today and noticed the tires aren't wearing evenly...less tread either on outside or inside of tire, on a couple of them. Please see the attached crude diagram. I used a 6-foot aluminum level across the tires on each side. I would think the proper axle alignment would mean that each tire would contact the straight edge, for a total of four points of contact on each side. However, on the street side, only the front of the front tire and the rear of the rear tire contact the straight edge, there is a gap on the other end of each of those tires.
On the curb side, the front tire contacts the straight edge on both sides, and the rear tire sits inbound and doesn't contact the tire at all.
How bad of a problem do I have?
05-23-2018, 08:25 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
I would measure from the ball center back to the same point on each side of the front axle and see what it is, may be hard to find that exact spot on each side and may be more accurate to remove the wheels and measure ball to center of wheel hub on each side.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
05-23-2018, 08:33 PM
The Aluminum Tent 3
Park City
, Utah
Thanks. What is 'ball center'?
05-23-2018, 08:39 PM
1974 Argosy 26
Morrill
, Nebraska
It's the hitch ball coupler. Might be difficult to find the center. Just hook the tape measure to the front of the coupler.
05-23-2018, 08:43 PM
The Aluminum Tent 3
Park City
, Utah
Thanks. I am taking the wheels off to get metal valve stems installed, so that will make it easier to take these measurements.
05-23-2018, 09:08 PM
1964 17' Bambi II
1961 24' Tradewind
Strasburg
, Pennsylvania
Literally underlying question...is the frame square? You won't be able to tell that under the bellypan aluminum, etc. Axles squared to an un-square frame still leave you tracking wildly.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
05-24-2018, 08:12 PM
2011 31' Classic
Nellysford
, Virginia
We had bad tire wear on our 1999 Classic 30' Excella, too. Took it to Jackson Center and had wheel alignment. Completely fixed the bad tire wear. Worth the expense. It is said that no one else should be permitted to try it. The fixture they use at JC is unique, that's for sure.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
05-24-2018, 08:25 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Also need to make sure that you have pulled the trailer in a straight line to remove all flex and torx from the tires. May be better to check with tires off the ground.
05-24-2018, 08:41 PM
1999 34' Excella
Hillsboro
With new axles, I measured from spindle to spindle on each side.. they are equal. I then installed tires then used 8foot long fluorescent tubes to ch comas you did. All square. I spun the tires to account for variances.. pretty much equal within about 1/64”... accounting for tire variances.
There is NO SLACK or n the bearings/spindles when rocking the tires when off the ground.
I have heard there have been some of the “no service” axle spindles which have had issues. Even our brand new axles had the bearings preloaded improperly. Perhaps worth checking in your case, too.
According to Airstream there are specs for “toe”... call them.. they are helpful!
Peace and Blessings..
Channing
WBCCI# 30676
05-24-2018, 08:53 PM
Oswego
Ok, I haven't read every post, but the only thing that is important is the distance from center of hitch ball to each spindle end. I dont care if frame is square....it can run dog legged all day if the axles are set squared to center of ball. Remove wheels, get a measure to each spindle end.
-Rich-
05-25-2018, 07:15 AM
1974 Argosy 26
Morrill
, Nebraska
I agree with post #10
05-25-2018, 09:20 AM
Moderator dude
1966 26' Overlander
Phoenix
If the axles lined up as measures the trailer can not run dog legged. The metal of the frame may not be square however the axle(s) will be perpendicular to the center line axis of the trailer.
>>>>>>>>>>Action
05-25-2018, 10:18 AM
1991 25' Excella
Santa Ynez
The triangulation measurements from ball to spindle is assuming the axle itself is true and not compromised in any way.
More info than you maybe wanted to know here.
http://www.trailer-bodybuilders.com/...mc-manual-and-
Will Rogers
Alan
05-25-2018, 10:28 AM
The Aluminum Tent 3
Park City
, Utah
Thanks all. I will do a series of measurements with trailer on jack stands next week when I pull the wheels to install Centramatics and metal valve stems.
