06-13-2008, 04:55 PM
#221
Baltimore
, Maryland
I had two very easy projects that went beyond easy. The first was this Grotelite reflector. They are not original, but I like the bling. I sandblasted them, eastwood rust encapselator, then silver encaplalator paint, and BAMMM.
Number 2 was this TV antenna mount. Stripped the wire, new end rings, vulkum, and stainless screws. Didn't even finish a rum and coke in the time it took.
06-13-2008, 06:24 PM
#222
Remember, Safety Third
Catfish Corners
, Georgia
You used the wrong screws on the TV antenna mount.
06-13-2008, 07:43 PM
#223
Baltimore
, Maryland
Did you wish to elaborate or am I to wait on a PM with the answer? There is a problem with stainless? I am going to do a scientific experiment on this.
Kip, sorry for the highjacking. I know Zep is usually the one that highjacks, but I can only say sorry. Extra karma coming your way. by the way, Hows that number stacking up Aerowood?
06-16-2008, 11:25 AM
#224
Catfish Corners
, Georgia
That was a very poor attempt at humor. I guess I'm going to stop even trying to make jokes any longer. Almost got my keester in a real sling in another thread last week.
JIm
06-17-2008, 05:28 PM
#225
1971 21' Globetrotter
Arvada
stricker plate
I put on a new main door striker. and continuing with my hatred of pop rivets and sheet metal screws I install self locking stainless steel 8/32 Keenserts to install the striker plate
06-17-2008, 05:38 PM
#226
Arvada
clearance lights
As stated in my last post I don't care for sheet metal screws so I installed sealed nutplates to mount the new LED lights. Below is a photo sequence from stepping up the hole size to #10 for the drill fixture, drilling #40 holes using the fixture, cleaning up filiform corrosion using a 3M bristle cone brush, countersinking the holes using a microstop with a #40 pilot to the final install of the nutplates
06-17-2008, 07:07 PM
#227
Catfish Corners
, Georgia
Kip, do you have to seal those nutplates on the backside with Vulkem (or other)? Forgive me if you answered that already.
06-17-2008, 08:43 PM
#228
Arvada
No, you don't have to, but I will. I also need to seal up the wire hole because the new LED's lights have the wires comming out at a different location.
06-20-2008, 01:37 PM
#229
1973 31' Sovereign
Portland
, Oregon
More about the brush?
Can you tell us more about the 3M bristle cone brush? It looks like something that I could use but I have never heard of them before.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
06-20-2008, 02:32 PM
#230
Arvada
Malcolm
Sure they work great at removing minor surface imperfections without digging in. We get them from one of our consumables suppliers. After looking them up they are actually called "Bristle Discs Rolocs" different grits 50, 80, and 120are available.
I found them at these sites
home
Discs and Rolocs
07-12-2008, 03:52 PM
#231
Arvada
Door of Worms
Have'nt worked on the GT for a while as we have been using it. First pic is at Turquoise Lake, Leadville Colorado. the rest of the pictures are of the door frame. I removed the old skin which was not 2024-T3 as it was dead soft. The door has been reworked (poorly) by a PO. The door must have been in some kind of accident due to all the damage. The pictures tell the story. I am also changing the style of latch. This mod will not be for the faint of heart, as some machining will be required on the door frame along with a new internal stringer. So off to see my buddy Bart, our certified aircraft welder.
07-27-2008, 08:26 PM
#232
Arvada
Front window
I still don't have my door frame back from the welding shop, so I decided to finish up the front window. I removed the window and then the frame as it had an obscene amount of silicon on the upper portion of the frame. I cleaned it all up, removed the foam gasket, and then cleaned and plugged holes that were no longer needed. I also drilled up a section of extruded piano hinge for the hinge of the not yet fabricated front rock guard, sealed it all up and riveted it all back together. A full day. I'm working alot of overtime right now, so I'm not getting as much done this summer as I would like.
07-27-2008, 10:06 PM
#233
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Kip, looks like the hinge is an integral part of the window frame! Am I seeing it correctly--you only have one side of the hinge installed, eg, the hinge wire is removed?
BTW, is that my wing window or did you put BEDFORDS' in? Did they have a different fit?
Zep
07-28-2008, 06:52 AM
#234
Arvada
Zep, The hinge is a separate piece. It's MS20001-8 Extruded Aluminum Hinge. I took the hinge pin out and removed the other half until I fabricate the front rock guard. The street side window is indeed the the outer pane of the dual pane that I got from you. The glass was thicker then the stock unit so I had to go with an injected seal. I have Tomorrow off so I am going to change a partial skin in front of the entry door.
07-28-2008, 07:44 PM
#235
1975 29' Ambassador
San Antonio
Your window looks very much like mine. How difficult was it to remove? What did you plug the holes that were no longer needed with?
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
07-29-2008, 09:12 AM
#236
Arvada
I slighty countersunk both sides of the hole and then shot in a MS20426AX-X (in this case it was a 4-2) rivet, then sanded it flush on both sides.
Kip
07-29-2008, 10:09 AM
#237
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Kip
Nice, Kip...very nice..
07-29-2008, 10:20 AM
#238
Arvada
Zep, here's a closeup of the hinge
07-29-2008, 12:14 PM
#239
1973 23' Safari
1977 23' Safari
Palmer Lake
Perfect, just like it's part of the frame. Can't wait to see how you build your rock guard, since I need one, too. Hey, make two while you're at it!!!
07-29-2008, 08:05 PM
#240
Arvada
more skin
Today I removed a portion of the upper side skin do to alot of previous damage. First pictures are of the damaged areas and then of the removed section of skin and the the new. I can't believe all of the silicon around the windows.
