Old 07-25-2011, 06:12 PM   #1
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
Neeed Help, caps for wall
Hello again, after three tries on the forum classified I am putting out a plea here for the wall end caps that are riveted onto the wall where it meets the inside ceiling. They are "U" shaped browm plastic, I need three. See pic, Thanks MPJ
ID:	135887   Click image for larger version
moparjohn is offline   Reply With Quote
Old 07-25-2011, 08:47 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I've been looking for those since 2006. If you ever find a source I'd sure appreciate a heads up.
Old 07-25-2011, 10:20 PM   #3
Wabbiteer's Avatar
Jupiter , Florida
Face Jackson Center and say Running Gear Balance five times fast while throwing pinches of drilled-out rivet shavings over your left shoulder... I could use two also, though the inner liner craters and splits kept the plastic damage to a minimum...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
Original hub caps, '70 Overlander. rayandre 1970 - 1973 Overlander 11 08-05-2013 07:46 PM
Cleaning the yellow stained end caps sirmill Upholstery, Blinds, Walls & Interior Finishes 33 03-04-2013 03:47 AM
13 piece end caps Dan G Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 06-02-2011 01:42 PM
End caps - vinyl or what - how to clean Sov1969 General Interior Topics 10 03-18-2011 08:41 PM
