02-04-2019, 12:43 PM
1970 27' Overlander
Texas City
Surge Protector Protector......
HI Forum!
I am ready to purchase a surge protector and am interested in the Progressive SSP-50XL....however, I'm wondering how I'm going to secure this when in use.......it's not cheap so i don't want to have to replace it ! Does anyone have this model or similar and how are you keeping it secured ?
Thank you for any suggestions !!
Teri
02-04-2019, 02:03 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
There is a metal tab on the male plug end with a hole in it. You can use a cable and padlock to secure it to the park pedestal. It won't stop a determined thief, but will slow them down.
Ray B.
02-05-2019, 09:54 AM
1970 27' Overlander
Texas City
Thank you Adventure AS.....i really appreciate that info !!!!
02-05-2019, 10:56 AM
2019 27' Globetrotter
Litchfield Park
I use a cable type bike lock. Before you go to the store, measure the opening in the metal tab. The first lock I bought was too big to fit through the metal tab.
Get something where the lock is as water proof as possible with rubber covers, etc. Last thing you want is to hook up your lock to keep your expensive EMS from being taken and then find when you are trying to leave that the lock is rusted shut...
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
02-06-2019, 05:39 AM
2015 30' Flying Cloud
Port Sanilac
, Michigan
I secure mine with a couple of heavy duty cable ties. Easy to cut with a pair of cutters but so are most cable lock devices. It will deter the casual thief.
02-06-2019, 06:12 AM
1966 22' Safari
Hilltop Lakes
I hook mine to the trailer's power cord while it's still rolled up in the rear compartment and then use a separate 30 amp rated extension cord to connect from shore power to the Progressive power monitor. That leaves it all locked up and out of sight.
Of course, this is only possible because my old Airstream has a power cable that is fixed to the circuit breaker panel and routed through a hole in the floor when in use. I just bring the extension cord up through that same opening.
02-06-2019, 09:15 AM
1970 27' Overlander
Texas City
Thank you everyone!! so many great options which is why you are my 1st
go-to whenever i need some advice......thank you for your time and guidance!
02-10-2019, 01:18 PM
2022 25' Flying Cloud
NCR
, Ontario
we installed ours inside under the closet in the 22FB
we have the surge guard 35530 unit with remote display
it has been working fine now for 2 years
08-06-2020, 09:54 AM
2016 26' Flying Cloud
Frederick
, Maryland
Heat damaged plug
last week when hooking up power I noticed one prong on my EMS-PT30X had some heat damage from our last camp site (didnt notice the damage when leaving). I used the progressive EMS-PT30X and it worked fine but am wondering if anyone has had this issue and be able to replace the plug on their EMS-PT30X and not have to buy a new unit. Even though it still seems to work fine I'm not sure I want to continue using it with the damage it has.
08-06-2020, 10:50 AM
2018 25' International
Slidell
, Louisiana
Burned plugs are common due to the rough treatment and poor maintenance the the campground pedestals get. The damage is likely limited to the insulation at this point. If the prong is loose you should replace it in my opinion. You can call Progressive tech support and see what they have to say. It's on their website.
08-06-2020, 10:58 AM
NCR
, Ontario
Wipe dielectric grease on the plugs.
this is cheap insurance for sites beyond you control
08-06-2020, 12:15 PM
2008 27' Safari FB SE
Miami
If you have a 50 amp to 30 amp “dog bone” adapter, you might want to use that. I do whenever there is a 50 amp plug available as they don’t get used as often and often have far less wear (slop).
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
