Old 06-24-2016, 02:09 PM   #21
Wabbiteer's Avatar
Jupiter , Florida
SAVE THE CURVES, make templates, even if they are crumble mealy and obnoxious...
A good flavor of MDO sign makers plywood with proper priming and 3x coats of porch paint is about as forever as me, a mere mortal, can aspire to... with the drop in petroleum prices there may be price reductions on Nyloboard or the like but I seriously doubt it.
If you've read the post you were flooded with information along with the blather, just note I indeed lucked out and found MDO in 49" x 99" inch so I could overlap, w/ glue and screws, over the frame cross members.
To those who wanted Jackson Center to use their choice of product for flooring, I've read here before that thats been soundly refused many times over the years.
Pressure treated lumber would eat iron and aluminum alike, note the epoxy coated or stainless steel fasteners they use on outdoor decking - besides that the junk outgasses unhealthy compounds for years that outdoor wind, sunshine and rain diminish pretty rapidly...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 06-26-2016, 05:45 AM   #22
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
I also have a 28 ft Intl with rotten floor in 2 soft spots, front and back and I feel this is quite common based on my research.
I had two soft spots that I THOUGHT were rot but after cutting the vinyl and looking I found happily that it was nothing. Then came the new floor.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 07-19-2016, 08:48 AM   #23
vis0rd0wn's Avatar
san jose , California
Question for all you floor experts. On a 2006 Bambi 16 does the subfloor go under the shower, sink/range, closet? If so, how do you replace the subfloor under these obstacles?
Looking at purchasing a used 2006 with floor rot and want to know better if it is worth it or there will be sections I can't get to that will require a full gut to fix. Thanks.
vis0rd0wn is offline   Reply With Quote
Old 07-19-2016, 08:57 AM   #24
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
What type of new floor did you install? I need to do the same, having been through about same thing as you, and am looking for ideas/recommendations.
Thanks!
Old 07-19-2016, 09:01 AM   #25
Rich W's Avatar
I'm In , Kentucky
When I was in JC getting a soft spot repaired I asked about replacing the vinyl flooring. They said everything has to come out, that's the only way they would do it. So if they take everything out to do the vinyl, they'd do it for the sub-floor too, I would think. The service guy said the bath area was especially difficult. The more you can do yourself, the more money you save.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 07-19-2016, 09:07 AM   #26
Luminous
LY007's Avatar
1983 27' Excella
Vesuvius , Virginia
I bought a thirty foot triple axle race car trailer a few years ago from a small company in PA. They do not use any plywood at all in their construction. Aluminum floors and walls. One piece roofs - no leaks. They do not have any dealers and most of their trailers are made to order. Nice people, superior product. I never had a single problem with it.
Airstream could save themselves and their customers a lot of time, money, and grief if they would ditch the plywood floors. Sure it would cost more up front, but it would be way way cheaper in the long run.
http://www.goldrushinc.com
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
Old 07-19-2016, 12:34 PM   #27
Tampatomgirl
1990 34' Excella
Zephyrhills , Florida
Does anybody have a link to replacing a rotten section with removing the body? I can't imagine it's that difficult. Thanks. I have a small place up front that i need to replace.
Tampatomgirl is offline   Reply With Quote
Old 07-19-2016, 04:27 PM   #28
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
when ordering a brand new Airstream from JC....
..I wonder if the purchaser could bring in their own Coosa subflooring and ask that it be used instead of the usual plywood subfloor material?
duncans is offline   Reply With Quote
Old 07-19-2016, 10:43 PM   #29
babsinFL
jverduzco's Avatar
2007 28' International CCD
Naples , Florida
so, what was your soft spot? did you do a full vinyl floor replace where everything came up off the floor first or did you figure out another way?
jverduzco is offline   Reply With Quote
Newbie needs advice on fixing rotten floor Lyvettely Repairing/Replacing Floor &/or Frame 32 11-26-2014 01:48 PM
What to do about my rotten floor??? utahredrock Repairing/Replacing Floor &/or Frame 15 11-03-2011 12:38 PM
rotten floor by door colin57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-05-2008 09:17 AM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 12:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 08:03 PM
