Old 01-05-2011, 04:35 PM   #21
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Originally Posted by soldiermedic View Post
I think you'll find that everyone here will agree that you need to do it over again. As Frank states, the green wood contains copper (correct me if I am wrong), and will cause major corrosion with the aluminum. The monocoque design of an airstream requires that the integrity of the floor, frame, and shell all be a strong unit. The non continuous boards will have little strength compared to a sheet of plywood.
Steve
Am I understanding correctly that I will have to remove the inner skin to replace the plywood and new elevtaor bolts? Does the rear belly pan have to come off too or not?
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 01-05-2011, 07:06 PM   #22
soldiermedic's Avatar
Florissant , USA
Yes, Interior skins need to come out, and some of the belly pan will need to be taken down. Use new elevator bolts as well.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 01-06-2011, 04:22 AM   #23
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
OK - thanks for the info, no sense in doing a half-baked repair. Will any of the big box stores carry new elevator bolts?
Air Cid
Reese WD Hitch
Old 01-06-2011, 04:45 AM   #24
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
I see from other posts I'll need 1/4 20 elevator bolts but cannot find a post about which length to buy. Stainless or gavanized best? Wanted to have the bolts ready for the re-do.
Air Cid
Reese WD Hitch
Old 01-06-2011, 05:06 AM   #25
Baltimore , Maryland
Go to Fastenal. They come zinc or black coated. I think 1 1/4" is plenty long. You need nuts too. I use nuts, washers, and lock washers. I also bend the remaining shaft to keep the nut from coming off. Better safe, than asked to repair it over. You will also need a forstner bit to counter sink a hole in the plywood.
I strongly encourage you to read more threads and also peoples blogs that have done this work. It is not hard, but must done correctly. I sense a little of "learning as you go", and you need to be very sure about what you are doing.
Old 01-06-2011, 09:13 AM   #26
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Thanks for the info - its completely learn as I go on this and I appeciate the inf offered here and on some of the other posts I am now begining to read - should have done this first - guess I thought putting in a section new plywood was a no brainer....NOT
Air Cid
Reese WD Hitch
Old 01-06-2011, 09:50 AM   #27
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
I "cheated" by using an air gun to tighten the nut so the head pulled into the wood. I reasoned that compressed wood would be harder. With hindsight, it was possibly a little quicker, and one less tool for me to buy, but with a do-over I would use a forstner bit too.
TX-16
Dave Park is offline   Reply With Quote
Old 01-06-2011, 10:03 AM   #28
Dave, you got lucky. Most bolts are made of the cheapest metal alloy that will still meet the code minimums for grade. I have broken many of them just using a socket a little exuberance.
Old 01-06-2011, 12:37 PM   #29
Dave Park's Avatar
2005 22' Safari
One broke out of about 30. I got them from an aircraft supply place years ago. I hear they're not so good these days.
TX-16
Old 01-06-2011, 01:40 PM   #30
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Guess where they are made? Sal.
noreen&sal is offline   Reply With Quote
Old 01-07-2011, 02:01 PM   #31
Florissant , USA
It's great how this thread makes you think about things when looking at trailers to buy.
Here I was, an accepted offer made on a restored to original 56 Overlander. New floor, all original appliances working, polished...nice. As Dave Park and I were looking at some of the pictures, we noticed that during floor removal, the lower interior skins were still in. This threw up a red flag. I sent an email asking the owner how he replaced the floor without the lower skins off. "Simple, I notched out around the original bolts, and laid the plywood in". I told him that a main part of the monocoque strength came from this area, and he said that his floor was very strong, and after traveling all over it had not had a problem.
Needless to say, I am glad I didn't send a deposit in. I would have had to replace the entire floor again.
Steve
Old 01-10-2011, 10:20 AM   #32
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
After reviewing another thread under this forum topic I am leaning toward using nyloboard for the redo on my floor repair. I plan to use the 3/4 inch G2 version and plane the edges to 5/8 as HiHo did in his repair. Will contact the company though to ensure the product can be planed but it seems like it should work. That way when leaks occur again in the far distant future the subfloor in that area will not need a redo.
Air Cid
Reese WD Hitch
Old 01-10-2011, 10:57 AM   #33
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Nyloboard discussion here:
http://www.airforums.com/forums/f36/...tml#post936112
Air Cid
Reese WD Hitch
Old 01-16-2011, 06:13 PM   #34
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
don't do this at home
Took some pics of my failed repair so that you can see the error of my way. First a pic of the plywood installed upto the wall - tight on the sides and gap of about 1" on end near rear door. Thought was to 'insulate' the plywood from leaky wall or whatever. Second pic is close-up of the edge - c-chanel was filled ithe 5/8 green treated (another mistake), caulked into place(yes, another mistake), and once that was done I placed the plywood in, fastened it down and put spray foam around the boarder to seal air leaks (yes - I know - now). Third pic is of fully clogged c-chanel. That caulk is very tough - unforatuantely it worked as adverised (tied removing some tonight). Four is a delightful representation of my blue foam belly insulation and a large perimter of c-chanel waiting for me. Three and five also show the nicely rusted and bent elevator bolts.
On the happy side - the forum kept me from complete disaster. This is an easier redo than a failed monocoque frame AND shell. Once I pick up my nyloboard and get the c-chanel clean I wil post some more pics.
ID:	119458   Click image for larger version
ID:	119460   Click image for larger version
Air Cid
Reese WD Hitch
