01-03-2011, 05:18 PM
1991 34' Limited
Tyler
Is it a 'do over' ??
My ambition may have exceeded my knowledge (not the first time). I removed 3 feet / total width of the rear floor in my AS. Removed all of the rotten OSB in the chanel and left the screws in place. In stead of trying to fit the new plywood into the chanel, I placed 5/8 green treated wood strips in the chanel. I then cut the new plywood to fit up to the chanel, filled in around the screws, wood strips, and space between new plywood with caulk. Screwed plywood into the frame members in 10 different locations. Now, after reading posts in this form I wonder if working the new plywood in around the scews would add to the trailer's integrity enough to re-do the whole job. BTW I replaced the fiberglass in the floor with 1" of blue strofoam with gaps filled in with the expanding spray foam to seal air leaks.
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
01-03-2011, 05:23 PM
1974 31' Excella 500
Charleston
, South Carolina
Pics..
01-03-2011, 06:07 PM
Baltimore
, Maryland
green wood+ aluminum= big problems
sheet goods not continuous= big problems
01-03-2011, 07:51 PM
Florissant
, USA
I think you'll find that everyone here will agree that you need to do it over again. As Frank states, the green wood contains copper (correct me if I am wrong), and will cause major corrosion with the aluminum. The monocoque design of an airstream requires that the integrity of the floor, frame, and shell all be a strong unit. The non continuous boards will have little strength compared to a sheet of plywood.
Steve
01-04-2011, 03:05 AM
Baltimore
, Maryland
perfectly stated.
01-04-2011, 04:36 AM
1991 34' Limited
Tyler
The 5/8" plywood is continuous all the way to the chanel. I was hoping that was enough. If I understand other postings, their new plywood went in around exisiting screws in the chanel. Does the extra bit of plywood in the chanel add a lot of needed strength despite not being fastened in the chanel? If so, I guess i'm in for a long weekend. Thanks for the info everyone. I should have read the posts BEFORE starting this repair
Air Cid
Reese WD Hitch
01-04-2011, 06:51 AM
Oswego
[QUOTE=tvanwave;933614]
Loosly defined, an AS monocoque build, the shell is part of the floor is part of the frame as far as structural support goes. The typical SOB is a shoebox sitting on a skateboard (no structural integrity other than to support it's own box construction).
Anything you do to interrupt the strength between the floor and shell, or floor and frame, will significantly harm structural integrity. They must be "locked" as one piece or structure.
01-04-2011, 06:56 AM
Florissant
, USA
So basically the previous person working on it took out the rotted wood. When it was replaced, the wood was notched where the old bolts were that attached it to the frame?
This is oddly familiar as my trailer must have had the same person working on it. Was it anything like this pic below from my old 53 Flying Cloud?
When bolted through channel, floor, frame, and riveted to the shell, the strength is considerable.
By not having the whole sheet of plywood and using the small strips, you have less area for the stress, flexing, and pressure of movement to be distributed. This could lead to failure.
Also, the shell when connected to the floor channel and frame is actually holding up that floor when you walk on it. If you don;t have the plywood underneath it to the outriggers and connected to channel, you could run the risk of breaking parts of the floor.
These are only my experiences during my time here and the rebuild of my old 53. There are others with infinite more experience who can assist you further. My old blog as seen below in my sig chronicles the 53 up till i was forced to sell it. Feel free to look at the trials, tribulations, screw ups, etc.Steve
01-04-2011, 07:51 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I have a similar problem coming up. Smaller area. I think it would be worth it to you to do it over. I am going to cut the plywood into 2 piecies and try to get the edge of the plywood into the channel. Then double the plywood from underneath over enough area to really make a good joint where the cut in the panel is.
01-04-2011, 07:56 AM
and my trusty lab Helga
1965 17' Caravel
1985 32' Excella
Midland
, South Dakota
You know i was wondering with all the floor problems why don't people use 5/8 aluminum sheating? Rip the shell off and go for it wile your in there box the hell out of the frame and stick it all backtogether. I am cosidering it on my 31'er
01-04-2011, 10:21 AM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Maybe one reason is expense.
A quick look found 5/8 aluminum plate at MetalsDepot® - 3003 & 6061 Aluminum Plate. A 4x8 foot sheet is $1,270.08.
Then there is weight, .625x40x96=2,880 cubic inches of aluminum, or 1.667 cubic feet. Aluminum weighs 169 pounds per cubic foot ( How to Calculate the Weight of an Aluminum Plate | eHow.com) yielding a total weight of 281.667 pounds for a 4x8 foot sheet of 5/8 aluminum plate.
Vaughan
01-04-2011, 10:24 AM
1981 27' Excella II
mays landing
, South Jersey
Why 5/8? Building a battleship? Sal.
01-04-2011, 01:37 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Typo
Originally Posted by vswingfield
Should have been .625x4 8x96=2,880. Oops.
Vaughan
01-04-2011, 02:16 PM
2005 22' Safari
Hyde Park Place
, Ohio
So THAT's how they make different length Airstreams. They use different width sheets, then cut off the left over frame!
TX-16
01-04-2011, 02:23 PM
1957 26' Overlander
Saint Augustine
Would it work?
Rae
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
01-04-2011, 03:10 PM
1991 34' Limited
Tyler
No but that was what I was planning as the re-do. I se via your post and others that notching the replacement plywood will not solve much. I don't know how to get at the exisitng bolts, slide in an new floor section, then re-bolt the floor w/o lifting the body off (not a viable option for me). Maybe that process is covered in other posts? Thanks for the reply.
Air Cid
Reese WD Hitch
01-04-2011, 03:48 PM
Ilfracombe
, North Devon England
i will put a couple of pics up tomorrow on how im doing mine .
i cut the floor out then got a grinder to all the old bolts in the U channel and screws then cleaned the under side of the channel . then cut the new sheet of ply and did one side at a time so the join of the boards is in the centre of the AS front to back with the other join 4 foot from the back.
hope this helps
01-04-2011, 04:10 PM
1991 34' Limited
Tyler
hope this helps
Sounds good - I'll be interested in how the new bolts are placed through the new floor. All I can imagine is removing the interior skin to finish that part.
Air Cid
Reese WD Hitch
01-04-2011, 04:12 PM
1991 34' Limited
Tyler
hope this helps
Forgot to insert - this link has a lot of good info on our respective problem http://www.airforums.com/forums/f36/...oor-54952.html
Air Cid
Reese WD Hitch
