11-24-2010, 10:57 PM
#181
steel/aluminum fabricator
2004 22' International CCD
Penticton
, British Columbia
Originally Posted by TankerIP
I may have asked before, but can't search out my post or answer, so here goes again:
Does anyone know about frame problems on the International AS models? I have one and think my frame is still okay. Is the CCD frame any different than that on the AS? I thought they would be the same frame. If the frames are the same on the two models, why don't we hear of complaints from other International AS customers?
And, why is the frame problem always on the curb side of the CCD?
Fortunately, I don't see any problems on my frame, but I do wonder with all the discussion going on.
The frames are probably the same only ccd models have an open interior design on the curbside. The streetside is reinforced by lower cabinets,stove,fridge. Curbside is open with no structure. A wimpy dinette flapping in the breeze is all there is. And even that is held in with screws that are too short and aluminum rivets.
11-24-2010, 11:52 PM
#182
2003 22' International CCD
1977 31' Excella 500
1966 26' Overlander
Shelton
I agree with Zedex but if your B & G tanks are behind the rear axel, and the frames are the same, the frames will buckle. Keep your tanks empty.
11-25-2010, 05:32 AM
#183
Spotsylvania
, Virginia
Don and Zedex,
My last six digits of my 2004 are: 515825
I had my frame inspected in May and no cracks were found. I have low mileage on it, tow with an '97 F-150 and no water in the tanks.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
11-25-2010, 07:27 AM
#184
Kiln
, Mississippi
Originally Posted by rseagle
Don and Zedex,
Smart, one of the AS tech's implied that ANY water/material in the black tank would put excess stress on the back of the frame while towing. I also have the grey empty but do keep fresh water in the centerline fresh water tank to keep the center of gravity of the trailer low while towing.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
11-25-2010, 07:29 AM
#185
Hillsboro
Originally Posted by zedex
Well. I talked to Jim today at AS. He is sending me a kit to beef up my outriggers on my 04. I will put em in when its not -17C outside.
The cost of the replacement outriggers is minimal compared to the labor to put them on. The factory payed to have mine put on. If you plan on doing it yourself you had better have a lot of time and skill. And use a MIG or TRIG welder.
Good luck.
11-25-2010, 07:36 AM
#186
Hillsboro
Good advise. And NO bumper stickers on the rear bumper either. Every little bit helps.
11-30-2010, 07:25 AM
#187
Seattle
I have cracks (insert obvious joke here even tho I am not laughing). What is my next step? Its not as if I can go running to the factory in Ohio.
Julianne Jill Campbell
2003 International CCD
11-30-2010, 11:10 AM
#188
Kiln
, Mississippi
You can ask AS for the frame stiffining kit - it should be delivered free to you, they know there is an issue. They may ask for photos for proof. You will then be on the hook for the welding unless you can talk them into having a local AS dealer/shop do the work and bill them. There are varying success stories out there on having them help out with the tab.
No laughing matter, frame cracks are a pain - with the sub-floor right there, it's hard not to burn and damage the floor underlayment and floor itself. Plus, you just don't weld them on in any old fashion - there is a need for caution not to weaken your frame rails when the heat is applied.
Best of luck.
Mike
12-01-2010, 07:19 AM
#189
Hillsboro
Best of luck.
Mike
Mike, that is good advice. As you know, I have been there-done that. I feel sorry for her. I think she is a full timer too.
12-01-2010, 07:32 AM
#190
Seattle
I'm not a full timer yet but I've been known to spend months at a time on the road in my Airstream. This issue seriously bums me out but thanks to all of you I know about the problem and can nip it before it gets too bad. Right now it looks as tho its the outriggers that have cracks not the frame itself. Going to take "Lucy" to my local rv repair dude, have the wheel bearings packed, while the tires are off I can get a better look and take the pics to send to Airstream. I sincerely hope that Airstream steps up and stands behind their product. I mean after all I love my silver pod so much I have a freakin' Airstream tattoo!
~Julianne
12-02-2010, 07:10 AM
#191
Hillsboro
~Julianne
Remember i invited you to visit me at NTAC anytime. I want to see if that tattoo is real!
Your plan to take it to a dealer is good but let me say this:
1. the reason the outriggers failed is because the frame bent rear of the axle. That put added strain on the outriggers and they couldn't take it.
2. You might consider having the factory do the repairs. They will charge you their standard labor rate but at least they have done this before, they know how to do it right and they do good quality work. When I had mine done it was a local airstream dealer and they botched it. Also it would be nice to take it to the source and rub their nose in it.
I think you have my e-mail address so feel free to contact me there and I can tell you things I can't on this media.
Good luck.
Don
12-08-2010, 03:55 PM
#192
Seattle
Frame inspected today and it isn't pretty
The picture are not great because the Tech was holding his flashlight on the cracks
12-08-2010, 04:03 PM
#193
Seattle
By the way my '03 only has 18,700 miles on it. I have always towed correctly, have not done any 'off roading' and have taken extremely good care of my trailer. I am the original owner and have all the paper work for everything that has ever been done. I am beyond upset, concerned and freaked out. It's not as if I can cruise to Ohio and have the factory take care of this and so far in my research there isn't an Airstream Dealer near me with a good reputation. If someone knows of a place in Arizona where I can take my trailer to have her repaired and have peace of mind please let me know ASAP. Obviously I spent a lot of money on my Airstream and was planning on a long and happy future of traveling. I feel like someone punched me in the stomache and walked away laughing.
12-08-2010, 05:03 PM
#194
Kiln
, Mississippi
Have you talked with Airstream public relations? Have you gone above the shop level at Airstream and asked for help? The shop manager will tow the company line on this ask for his boss. I can understand your grief - I had the same feelings about my investment. You have some options as I stated before, they have on ocassion paid for repairs on older units, in shops other than a AS certified shop - this is rare but it has happened. Get them - in writing (email, snail mail, how ever) to respond to your complaint. If you call, keep a log, write names down, keep at it. They will send the kit I mentioned before to stiffen your frame and outriggers, call them for it. The man I got some relief on my bill for my floor repair - and it was minor - was Dave Schuemann (sp?) but he would listen. Call and ask for him AFTER going through the painfull calls to Chris and his boss (a name I do not like to mention) but Dave is above them (department head ?) BUT he will ask if you talked to the shop people first. There is a company system to keep people from flooding upper management with questions.
Keep up the calls. BTW - I know they read this - TOO BAD.
PM and we can talk - you won't like what I have to say. I can pass on my cell number. BTW the frame design and PRODUCTION SYSTEM is flawed, they have admitted such with the stiffining kit.
12-08-2010, 05:40 PM
#195
Princeton
, New Jersey
I would call Jackson and ask for the correct address for Bob Wheeler, President of Airstream Inc. and Richard E Riegel Chief Operating Officer, it was under his so called successful watch that your unit was made. I would write them directly explaining your problem and including the URL for this thread. They will do nothing until they begin to see it effecting future sales.
Additionally I would copy the Officers of Thor Corp, there names and address can be found on this page.
THO Profile | Thor Industries, Inc. Common St Stock - Yahoo! Finance
2004 Excursion 4x4
12-08-2010, 06:34 PM
#196
1966 26' Overlander
Shelton
Airstray in Shelton, WA.
Julianne, Unfortunately, no matter what repairs we have done, none of us will ever have peace of mind or faith in Airstream. Jim
12-08-2010, 06:52 PM
#197
1966 26' Overlander
Shelton
MT tanks!!!!!
Empty tanks is good advise for many reasons; stress on the towed as well as towing vehicle, helps with anti-sway, etc, etc, etc. but I don't give a dam- what anyone says. The frame under ANY vehicle should be engineered, constructed and tested to, at least double the required strength. What would happen if Ford, GM or Chrysler required us to only put 10 gal. of fuel in or cars? Airstray
12-09-2010, 07:22 AM
#198
Seattle
Bon Bons?
Great, I'll give up the dream and sit around my house, watch tv and eat bon-bons. I DON'T THINK SO! I've invested way too much into the Airstream way of life.
12-09-2010, 04:13 PM
#199
Hillsboro
You are being ...... and not even being .....
My first frame failure was much worse than your pics show. I think you can at least tow yours. Mine was a complete collapse and untowable. Do not plan on any long trips right now. If you want to contact the factory and deal with them, I can help. Contact me on my e-mail address since this is being monitored by Airstream.
12-09-2010, 04:17 PM
#200
Seattle
I am in contact with Airstream and working on getting this resolved. Thanks.
