02-04-2011, 11:16 AM
#21
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland
, Maine
Originally Posted by Ken J
Again - we are comparing to this to a popup - has limited facilities, dry rot to me sounds like soft floor, not "floor is gone" - and nothing wrong with using epoxy for a soft floor - I should mention make sure you take a hair dryer and dry it good before you put the epoxy down. I've done it and it works well - long term needs to replace the some or all of the floor and he's said above it does not smell too bad.
So we are talking about making this trailer into something that can be used and enjoyed for now, then as money and motiivation comes about, can be upgraded.
I also hear local trips - perfect for that
From the pictures I see a decent trailer that could be a nice hobby
The kids will have a blast and will always remember Dads old trailer that this and that was messed up on it, but over time the whole family got involved in fixing it up and really having some great times, not only camping but working on it
All in all sounds pretty great to me - you should have seen what I started with....
Ken J.
I just do not see how this work could be done with a few thousand dollars considering all the missing fixtures. I would advise that the floor is one of the things that holds the trailer together and the epoxy bandaid approach really is not an ethical repair. The floor is soft because of moisture and until the source of that is fixed it will be a problem.
Suggesting 61 start repairs on his limited resources without completely explaining the entire process while waxing romantically about how great it will be to involve the kids & gramps sounds like one of those morning in America political ads from the mid eighties. Look how that turned out!
All repairs should be long term when repairing an Airstream. This is the only way to really make it last. And hold value while not having to go back and repair it again.
Ken....what bothers me about the approach is...is that I have heard it before from guys trying to sell a trailer with soft and missing floors. Just trowel in some epoxy goo and it will be good as new" ......but they luckily never even got around to that. So Mr. Ambassador would be much better off becoming the seller....minus the floor fixing advice.
02-04-2011, 12:59 PM
#22
1961 28' Ambassador
1975 31' Excella 500
Bladensburg
, Ohio
My floors are not soft... I just can see a very small piece of the floor right inside the door, under the linoleum, where the wood is kind of rotted. It is only maybe 3-4 inches square. It's not soft, and is not rotted through... just has been wet on top. The other area is under the sink along the rear of the trailer, it is out of sight and can not be walked on so there is no danger of the flow falling through.
To be honest the floors are fine without any work, there are not any areas that I can see through or feels soft when I stand and bounce on it.
I know I'm new, but the PO owns his own business and works in the oil field around here... he's very savvy and he said the floor is sound. He put in laminate flooring about 5-6 years ago and the only leaks I have found are around the seals on the windows. I cannot locate any others and I've been in it every time it rains hard to check for any wet spots. The floor should be fine for what I need.
All trips will be 30 miles or less - and not over 55 MPH. Roads are hilly and curvy so speeds likely will be 35-45 MPH.
The original fridge is there, and as of the last PO check (which I believe) was still working. If nothing else, it is there and can be an ice-box. I have an electric mini-fridge I can put there for use at campgrounds if nothing else. And if that fails, we are old tent campers and have large coolers to sit on the ground outside the camper.
The toilet is there and works fine. The black water tank works - I just plan on getting a rolling tote and emptying into that for ease of use.
So - all I really HAVE to do is (1) fix the copper pipe break in the water line on the inside and I'll have cold running water to flush with and brush teeth, dishes, etc. We'll shower in the shelter house. (2) Make sure my brakes work and run a new electric line to them and install a 7 pole connector (3) Add a breakway switch (4) new tires (5) get some foam for the twin beds (6) Fix the broken vent cover (one end came loose, but still opens and closes)... and then I should be fine.
I think I can have all this done for under $1K... the rest are just little things I already have.
The body is in good condition, normal dents and dings, but no holes. Belly pan is good condition.
As I said - we're used to tent camping... so with a solid floor and electric we're already a step up... the only other thing, and it's the MAIN thing I am worried about is safety while towing. Hence, the need to make sure brakes are hooked up and a new 7 pole and breakaway is added. My mechanic buddy said the brakes and axles are fine for now.
Hope this clears it up somewhat.
02-04-2011, 01:04 PM
#23
1956 22' Flying Cloud
Durango
When I wrote the above I figured I would hear from someone who did not agree with me - thats ok - the trailer has lasted 50 years as is. I don't see it going anywhere fast and as 61 said above it is a solid trailer. There is nothing wrong with using epoxy - especially as I've said till you can get around to replacing that section of the floor depending on the size of the repair - you are right you should find the source of what made it soft to begin with - as far as sellers go - its up to the buyer to determine the condtion of the floor - we are not talking about selling it - we are talking about making it a usable trailer - I think this makes for a great thread on what do you really need to make a trailer useable.
You keep mentioning fixtures - they plan to cook over a fire - thats great! You don't need a full set a fixtures to take the trailer out and have some great camping fun. Even a porta potty in the trailer will be a step up from pop-up facilities.
We all don't have the same resources to fix these trailers up - I spent a TON of money on mine - we can't all do that but it doesn't mean we can't have fun and enjoy what we have - I've seen a LOT worse trailers traveling the countryside and these folks are having a blast with their trailers.
If I had a choice of keep this trailer or a pop-up or white box and I had limited resources - I would keep the trailer and work on it over time as suggested. And all I'm doing is suggesting how that can be done on a limited budget.
I say keep it and enjoy!
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
02-04-2011, 01:10 PM
#24
Durango
61 - The more I hear about this trailer it sounds like you have a great find there - and it sounds like you have gone through it pretty good -
Have a GREAT time with you and your family camping - 30 miles won't hardly even shake a rivet!
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
02-04-2011, 01:13 PM
#25
1961 28' Ambassador
Bladensburg
, Ohio
Oh, and I have NO intention of tearing anything out inside... all is present and original (minus the stove, heater, water heater, and tub). I added a new water pump. My only plan inside is to try and put some old wood restorer on the original woodwork to see if maybe it will shine a little and smell good.
I'm easy to please... I want (1) Safety for myself and others while towing (2) Reasonably waterproof, no more tent walls seeping water (3) Electric lighting, no AA or D batteries (4) a door... the rest is details.
Thank you all again for your comments. I appreciate and value them all.
We were given the camper by the PO, he is a very nice man and this was just sitting in his field. I'd have gladly paid him for it, but all he wanted was to see someone get use out of it. He lent it to a buddy who took the stove, water heater, heater, etc out for a supposed reason of they 'broke' when he used them.
I plan on nickeling and diming my way to a nice trailer by putting $1K into it each year around tax time. If the general consensus feels this is plausible... if not, then I'll sell it to someone with the money and time and skills to fix it up like she deserves. I'd LOVE to keep it... I've loved AS since I was a boy in the 80's and my Grandpa had several of them. You might say it's been a dream of mine for 30+ years now!
02-04-2011, 01:34 PM
#26
1977 Argosy Minuet 6.0 Metre
Colorado Springs
We have been enjoying our Minuet while restoring for the last 4 summers. Each winter I spend between $300 and $500 on the next project. So far new axle, counter, table, replaced gray and black dump valves, restored belly pan, replaced the vent fan, screens, some plumbing repairs, lots of little repairs that were mostly just time. Each summer it is a better trailer. We still need to replace furnace, curtains, upholstery, floor covering, some new gaskets, polish out the lexan windows, and paint the exterior. I want to add 30# Aluminum propane tanks, a second battery, and solar. Figure another 5-7 years and it will be complete except for the regular upkeep. I would recomend you keep the trailer, use it if you can and just keep picking at the project.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
02-04-2011, 02:02 PM
#27
Durango
61 - Hope you don't think I'm responding too much - some folks have all the luck - a free trailer is great!
I think your plan is VERY sound - get the running gear safe - get some cushions to sleep on - fix the plumbing (not a big expense - more time than money) and enjoy it this summer - when the summer is over, decide your project for next year and keep at it - it will get done. As you get into applieances/fixtures it does get pricey - but again pace it out and enjoy it.
Let us know what you find as you use it, you can learn how to fix it here - ask away with questions..
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
02-04-2011, 02:25 PM
#28
1967 26' Overlander
Winston Salem
, North Carolina
Hi,
Welcome to the Forums.
Wondering, why would someone remove the tub?
This trailer can be a work in progress.
Get the basics working and use it.
As funds become available, then upgrade the components.
Just my 2 cents..
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
02-04-2011, 03:11 PM
#29
1981 27' Excella II
mays landing
, South Jersey
Ken J.
I agree. Some of us Streamers are on fixed incomes and have to work with what we have. Enjoy the experience. Rome wasnt built in a day. e cant all have a "perfect" Airstream. That keeps it interesting.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
02-04-2011, 03:37 PM
#30
1966 24' Tradewind
Oak View
You can have plenty of fun even when it is mostly an aluminum roof over your head. When I had mine boondocking up at the ranch with no hookups, I accidently ran the battery down and then ran out of propane to boot. I still stayed the whole weekend and used my back up camping gear; lantern, propane cannister stove, cooler and warm clothes. Had a great time....
Glad to hear you are keeping the trailer, take your time getting it up to speed.
02-04-2011, 07:30 PM
#31
1961 28' Ambassador
Bladensburg
, Ohio
Thanks folks!
And reply as much as you'd like - feels good to have nice people truly discussing things instead of just arguing like the politicians.
This site and you folks are great!
