10-12-2017, 08:35 AM
#161
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by Dennawayne
Howdy,
My wife and I just started living in our 2015 30’ International Signature. I bought the 4gx with omnidirectional exterior antenna, how would you suggest mounting it. I was thinking directly to the top of the trailer or on top of a telescoping pole attached to the bumper. I would take it down when under way.I bought one amplifier for the TV that I would bring into the trailer once at a site and find a place to mount it and use theRV indoor antenna and hook it up to the exterior antenna. When it’s in the truck I use the candy bar and small magnetic exterior antennas.
Hi
It's way more convenient to mount the antenna on the roof of the trailer. One less thing to set up. One less thing to store someplace. The pole approach lets you do a directional antenna. That may be helpful in a few cases. It does add yet another thing to fiddle with getting up and going.
10-15-2017, 07:47 AM
#162
2006 16' International CCD
Steamboat Springs
Will try the directional antenna with Bambi TV antenna
Since I have another rooftop project going on, I decided to attach the directional Yagi antenna to the rotatable Weingard TV antenna on my 16' Bambi. I'm using the technique that Rocinante did by strapping an aluminum pole to the Weingard that the Yagi is attached to. When operating, the Yagi will be raised a few feet above the shell of the trailer, and pointed to the nearest cell tower. Unfortunately, the amplifier and desktop antenna will be directly below.
Will it oscillate? Who knows? I decided that even if it doesn't work, the system is still good if I ever get a hot spot card that I can attach an antenna to (without amplifier). And I will always have my current fall back, 20' of antenna cable that I can run to an external directional antenna held in place by a portable bike stand.
It'll be a couple weeks before the project is done, and maybe a couple weeks afterwards when I can do an adequate test on the road. But I will report back how this works.
2006 16' International CCD pulled by 2016 Toyota 4runner
10-29-2017, 09:19 PM
#163
2017 27' Flying Cloud
Fort Worth
I see that the unit comes with an AC adapter. Is there a way to power the Weboost using 12V DC?
10-30-2017, 02:55 AM
#165
Firedog1
2018 30' Classic
Woodbridge Connecticut &
, Venice Florida
We had a 12 volt outlet installed to power the weboost so we can use when boondocking and do not need to run house inverter.
Russ and Lisa
2018 Classic 30
2020 GMC Sierra 3500HD Denali Diesel 4x4
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
10-30-2017, 03:16 AM
#166
Sag Harbor
, New York
Our 2014 FC20 has a 12-volt outlet thankfully. Which weBoost unit do you use, plus an outdoor antenna?
Peter
10-30-2017, 04:18 AM
#167
1974 27' Overlander
Baltimore
, Maryland
Our weboost came with a hardwire 12V adapter. It converts to 5v DC. Ran the wire to the fuse box. We have the 4g-x RV.
10-30-2017, 05:26 AM
#168
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Our WeBoost 4Gx came with a 12V adapter, so yes you can get one. I installed a set of three 12V adapters where I wanted to put the WeBoost, in the cabinet above the dinette. Works great.
10-30-2017, 05:32 AM
#169
Fort Worth
By 12V adapter, I assume this is plugged into a 120V outlet? We plan to do a lot of boondocking so have little access to AC power. What adapter did you install?
10-30-2017, 05:41 AM
#170
Sag Harbor
, New York
I think he is referring to 12-volt outlets, the cigarette lighter style ones, as he said his weBoost came with a 12-volt adaptor/plug, which [from what I have seen] goes into the old-fashioned 12-volt outlets. Similar to this one IMO:
https://www.amazon.com/Wilson-Electr...HY8NN2KFKVDP36
Plugging directly into a 12-volt outlet, thereby eliminating the inverter [12-volt to 120-volt, then back to 12-volt] from the circuit, is more efficient.
In the old days, Airstreams had many 12-volt outlets, as shore power was less commonly available, as were generators. Our old 1985 25' in the 90's had a few:
-- head for 12-volt charging of electric razors
-- galley marine-style kitchen implements like tea kettles and immersion heaters
-- sofa/lounge area for misc. charging and portable radios etc..
Airstream eliminated the 12-volt outlets recently, and the new AS are less useful without them IMO.
"12-volt outlet" search results: https://www.google.com/search?q=12+v...=airforums.com
Cheers,
Peter
10-30-2017, 05:45 AM
#171
Fort Worth
Originally Posted by OTRA15
I think he is referring to 12-volt outlets, the cigarette lighter style ones, as he said his weBoost came with a 12-volt plug, which from what I have seen goes into the old-fashioned 12-volt outlets.
Ah....got it! Thanks!
10-30-2017, 05:56 AM
#172
Sag Harbor
, New York
Bill you grabbed that quote as I was still editing the earlier comment FYI, so you might want to read the full comment. Which weBoost do you have?
Peter
10-30-2017, 06:03 AM
#173
Fort Worth
Peter
Thanks for the clarification, I had planned to install some of these anyway as our Bose Bluetooth speaker that we use outside can be charged this way. I have not purchased the Weboost yet as I'm still a bit unsure of how to run the wires from the refrigerator vent to the console over my dinette. I assume people only put out the indoor antenna after getting to their location?
I am planning to buy the RV solution from 3gstore.com
10-30-2017, 07:41 AM
#174
Green Cove Springs
Yep, that's right. I installed a set of three 12V outlets for cigarette-style plugs, and I power the WeBoost 4GX via a 12V adapter, mentioned above, plugged into one of those sockets.
10-30-2017, 07:59 AM
#175
2004 28' Classic
Monument
I installed the WeBoost Home 4G. I mounted the external antenna on a tri-pod so I can easily aim the antenna at the strongest signal/cell tower and also I can maximize the separation from the internal antenna.
(With all this technology, I wish I could figure out how to orient these pictures... )
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
10-30-2017, 10:06 AM
#176
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The inverter is a disaster for running something like the WeBoost that pulls a couple of amps off of 12V. One cute place to pick up 12V are the wiring harnesses that lead to the lights in the various storage compartments. You aren't putting enough of a load on them to do anything crazy to the wires or fuse with a WeBoost. Dropping a 1,000W sub-woofer in that way .... not a good idea ....
10-30-2017, 10:25 PM
#177
Steamboat Springs
Rocinante, I'm following your system and attaching a directional antenna to my bat wing antenna...tomorrow. It will be an experiment to see if it is too close to the amplifier below. Worse case, it's still a useful antenna if we go the RF modem route.
Quick question if you get this- when you fished the antenna cable to the media cabinet through the light fixture- was that where it stayed? Or did you drill an additional hole in the interior shell? I couldn't see how the light fixture and the antenna cable could both fit through the same hole. Thanks!
10-31-2017, 05:38 AM
#178
Green Cove Springs
I fished the antenna cable into the area behind the radio (in our case it is a Sony). From there, I ran it into the area behind where the DVD player lives so any new holes in the cabinetry would be hidden. Then I used a hole saw as needed to get that cable up on top of the DVD cabinet, and mounted the booster there. Had to take out that DVD cabinet and the divider wall there, and re-install them to do this. Not too difficult, though time-consuming.
10-31-2017, 07:37 AM
#179
Steamboat Springs
Thank you. I looked up photos of your trailer model and see what you are saying. What I didn't understand is that your blog said that the cables were fished to a light fixture hole. Why would there be a light fixture hole behind the Sony in a totally enclosed area? Perhaps it was the same size hole, but no lamp.
My Bambi also has a Sony radio in an enclosed area. I once tried to get access behind the Sony by removing the dividing wall, but couldn't unhook the Audio switch plate (with wires attached) to remove the wall. The wires kept the wall from moving much distance, and I couldn't figure out how to unsnap the audio switch plate without potentially breaking something. I got the Sony radio removal tool, and may try removing the radio to gain access, and perhaps being able to snap out the audio switch from behind.
All of this is to gain access to the rest of the cabinet over the dinette, where the cellular booster sits. This is why I was thinking of merely fishing the cable to a light fixture in that part of the cabinet and avoiding the whole "removing the Sony and the wall" thing. I already have 12v power available. When I saw your references to a light fixture hole, I said "aha!". If I find it to difficult to remove the Sony and the wall, I may still do that.
10-31-2017, 11:11 AM
#180
Green Cove Springs
I'll try to reduce confusion: I drilled one hole in the external shell above each of the light fixtures in that cabinet. I brought the cable into the space between inner / outer shell fishing them in via the light fixtures, which I replaced after getting the cables where I wanted them to be. Sure, you could drill a separate hole in the inner shell if you wanted to, just above where you plan to install the booster.
Oh, and I did *not* remove the radio. I removed the DVD player and the cabinet into which it was installed. Then I removed the wall between the DVD player and the space where the radio is installed. On this wall there was already a 12V socket. If you have a newer trailer, it might be a USB port. That was relatively easy to remove. It's also a great place to install more 12V sockets, one of which you would use for the booster.
