10-14-2019, 03:06 AM
LP Pressure? How to check?
2002 classic AS. How can I check and confirm LP pressure? Stove and furnace work OK but I may not be getting enough LP to run the fridge and HW heater. Sorry about pictures - they appear sideways and upside down.
10-14-2019, 03:52 AM
2016 16' Sport
Miami
Google manometer. You can build one in 5 minutes for probably less then 5 bucks. Not counting the trip to Home Depot.
If you have a LP port you can check it from there. Just buy a male fitting for the LP port and a 4 feet of clear hose that fits snug on the fitting.
10-14-2019, 03:54 AM
2016 16' Sport
Miami
I have one in my garage that I built but I’m in Mumbai at the moment or I’d send a picture. You can find plenty of simple examples on YouTube.
10-14-2019, 05:57 AM
Oswego
I bit the bullet and bought one of these proper tools.
https://smile.amazon.com/Yellow-Jack...054053&sr=8-32
Still had to go to HD and get the correct sized brass fitting to connect to stove. Take your reading of 11" of pressure with all other gas appliances operating (furnace, WH, fridge). Mine was several inches low.
-Rich-
10-14-2019, 07:03 AM
2002 30' Classic S/O
Fleming Island
Considering the age, and looking at your regulator, I wouldn’t bother with checking pressure. I’d replace the regulator and associated flexible lines.
I had to replace the regulator on my 2001 and my 2002.
Al
10-14-2019, 07:25 AM
Oswego
X2^, but I have found brand new regulators which are not adjusted properly right out of the box.
Al
-Rich-
10-14-2019, 07:48 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I had a furnace problem. A mobile RV repair unit came and fixed it. He said the problem was low flow, due to a collapsed interior on the 30 year old flexible line between the regulator and the copper tubing. I agree with Al. Change the lines and the regulator and try it again. Then check pressure if you need to.
The mobile RV service took the furnace out and cleaned and tested and adjusted it on the tail gate of his truck with a propane tank and 12 volt supply. Put it back in the trailer and it did not work. Then he went to work on the regulator and eventually the lines.
I think you need some sort of flow meter to really test. I doubt if the static pressure tells all you need to know.
10-14-2019, 08:20 AM
Oswego
There is a diagnostic strategy for this. If static pressure is ok, likely around 13 - 14 inches, but pressure drops low, like 8 or 9 inches, regardless of adjusting regulator during dynamic flow, there is most likely a line restriction.
A healthy and normal regulator should be at 11" during dynamic flow, with all gas appliances running, and rise to around 13 - 14 when appliances are off. Then shut off supply at the bottles and the lines should hold pressure for a minimum of 20 minutes. (Recalling from memory the 20 minutes. Verify online.)
-Rich-
10-14-2019, 10:19 AM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
Al
I concur. You own an AS, don't cheap out now.
10-14-2019, 03:25 PM
2013 25' Flying Cloud
Wheaton
Just to provide context, regulated propane is very low pressure, less than 1 psi.
Greg
10-14-2019, 03:49 PM
1985 31' Excella
st. Paul
, mn
Like electricity / batteries .
You need pressure / voltage , and volume / current .
My view is that if I use either of the above , I need to learn about it .
https://gashosesandregulators.com/pr...latorfacts.php
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
10-14-2019, 05:14 PM
Thanks Al. I plan to purchase a regulator and the lines. Specifically, which lines do you recommend? Just the flexible ones? Anything I need to know before I swap out the regulator? I’m pretty handy - but we all know the little tricks make things easier?
10-14-2019, 07:20 PM
2019 19' Flying Cloud
Canyon Country
I bought 2 propane tanks that came with gauge at Costco. Works great.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
