We used our 2016 Interstate Grand Tour EXT Twin for a few days in late January during which time everything was working great.
I then placed the van in storage as follows:
- Shore power was plugged in and working
- House master switch was turned off
- Magnum display was showing that the unit was charging as usual
I Came back today to inspect the van and the Magnum display showed the com error and there was no house power. I started the van and everything powered up, but powered right down again when I turned the engine off.
I checked the DC voltage at the terminals by the Magnum and directly on the battery terminals and the meter showed 3V at both locations.
To fully describe my setup, I've made the following modifications:
- Eliminated the SB-164 solenoid
- Installed the Magnum DC Load Disconnect (DCLD) Pigtail Adapter
- Installed the Renology Amp MPPT solar controller and MT50 display
Since making these modifications I have stored the van on shore power for several 10 to 15 week periods of time with no battery problems at all.
Anybody have an idea what went wrong this time and what I should do to fix it?
Also, should I assume the Lifeline GPL-24T batteries need to be replaced?
Thanks in advance to anyone who can weigh in!
