04-12-2015, 10:25 AM
2012 Interstate Coach
Carlsbad
Carbon Monoxide Detector
All,
Were 1 month in to our '12 interstate. We recently had the carbon monoxide detector replaced by our San Diego Airstream dealer. I don't know if others have had this issue but now the defector (presumably new) is going off.. Does anyone have any tips on checking if we have a good/bad detector or if I actually have carbon monoxide in the van?
Thanks for your help!!
04-12-2015, 12:16 PM
2018 23' International
SANTA BARBARA
, CA
We had similar issue at same dealership. Sending you private message.
04-12-2015, 02:26 PM
2014 Interstate Ext. Coach
Sedona
Presumably you were not using anything that produced CO prior to it going off? The water heater (on gas), furnace and the generator all exhaust to the driver's side, so when using any of them, you should keep windows on that side closed.
04-12-2015, 02:55 PM
2013 Interstate Coach
Townsend
, Tennessee
We had the same problem with our CO detector about 6 months in.... Tech at the dealer said this was not an uncommon issue with this wired detector. I opted to replace it with the battery-operated one (same Model detector and base, just not wired in variety). Problem solved. Except that for it to be done under warranty, I would have to simply replace it with another wired-in detector (that may have the same problem). Small price to pay for getting rid of a sporadic problem.
FMCA # 436814
04-12-2015, 04:23 PM
Figment of My Imagination
From All Over
, More Than Anywhere Else
Another difference between model years for the Interstate. My 2012 came with a wired LPG detector, but a battery-operated smoke/CO detector. Since you have a 2013, that is probably the first model year to come with a wired CO detector.
04-12-2015, 06:49 PM
SANTA BARBARA
, CA
Weird, but, in our 2013, the CO2 is battery operated only. When we had our beeping issue, I contacted AS in Jackson Center to clarify this, because upon removal of the detector, ours had wires that were dangling but not connected. Jackson Center told us that in our model they were battery operated only, and that the wired should not be connected to anything. They looked it up by VIN number to be sure.
04-13-2015, 08:18 AM
2024 Interstate 19
Fulton
, Maryland
I had the wired CO detector replaced under warranty in our 2013 model after about 9 months. If you check the owners manual for the detector there should be a test procedure to determine if sensor is bad. Both CO and smoke detector do fail. I even had one in our new townhouse go bad after 2 years of use. Manufacturer replaced it free of charge.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
04-13-2015, 04:10 PM
2011 Interstate Coach
Overland Park
, Kansas
Most, if not all, smoke detectors need to be replaced after ten years due to the half-life of the radioactive element used in the sensor.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
04-13-2015, 06:57 PM
2005 22' Interstate
san clemente
02interstate and weirdstuff-----Suggest you check out Ricks Trailers in San Clemente, I have had very positive relationship with Tom and his wife and their very knowledgeable techs.
04-13-2015, 07:13 PM
SANTA BARBARA
, CA
Can he do warranty work?
Appreciate the referral. Good to know about an alternative.
04-13-2015, 07:44 PM
2005 22' Interstate
san clemente
Weirdstuff---I do not know, they do not sell RVs or trailers, but they have serviced and repaired a lot of units others would or could not. Call and speak to Tom and say the Doc with an Interstate suggested you call. Forgot, he is one of the HONEST guys and does everything he can to help.
04-17-2015, 05:50 AM
Waterloo
, Iowa
Just had our 2013 AI warranty work done at Jackson Center. One of the problems was the hard-wired CO detector that beeped even with a new battery. The fix was to replace it with the current-production battery-only CO detector. So far so good.
04-17-2015, 08:31 AM
2005 39' Skydeck 390 SD
Hillsboro
Mine got changed 3 times and I hope it's gone be good now.
04-17-2015, 11:32 AM
Newbie
Fort Worth
On a small almost unnoticeable label in the detector on my 2013 I found a warning that the 12V line must be disconnected before removing/changing the battery. No CO or Smoke detector problems since discovering that bit of information. Wish I had noticed it three detectors ago!
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
08-01-2015, 08:17 AM
Sedona
My CO detector started beeping yesterday for no apparent reason. 2 loud beeps every 30-40 seconds. The manual says it means something like "end of life". This is a wired detector.
I turned off the coach batteries and removed the 9v internal battery, but it's continuing to beep!
I haven't found a way to stop it since the labels on it discourage opening it up. Any ideas?
08-01-2015, 08:50 AM
2024 Interstate 19
Fulton
, Maryland
You also have to remove the 12V wire to the detector - it should be accessible if you remove it from the ceiling.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
08-01-2015, 10:59 AM
Overland Park
, Kansas
That's interesting because when I turn off the house batteries, my CO detector no longer responds to the test button. Need to dig out the manual on it and see how it's set up.
08-01-2015, 11:49 AM
Sedona
- - Mike
Ah yes, I hadn't spotted that if you carefully pull out the wires that go up into the ceiling, there's a plastic connector. Silence at last! Thanks Boxster.
Incidentally, when I completely removed the detector, it continued to beep until I removed the battery.
Mine has 3 wires going to it, which look like chassis 12v, coach 12v and ground. I think I read somewhere they may now be using household-style battery-only versions.
08-01-2015, 02:24 PM
From All Over
One step forward, two steps back. My 2012 Interstate has a battery-only CO/smoke detector. Two AA batteries last about a year.
08-01-2015, 02:25 PM
Overland Park
, Kansas
I erroneously said my CO detector when I really meant my propane detector in Post 17 above.
