08-04-2017, 01:40 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Hitch drop 2500 HD
I just traded my 2015 1500 Silverado pick up and on a 2016 2500 HD Duramax diesel and I'm going to have to purchase a new receiver drop for my equalizer hitch as my current weight distribution hitch in the lowest position is still about 4 inches too high for the trailer to ride a level. Has anyone else had the same experience being as the 2500 HD rides much higher than the 1/2 ton Silverado
Thanks for the input.
08-04-2017, 02:36 PM
2008 27' Safari FB SE
Miami
Similar situation -- my Titan XD was four inches taller than my 2004 Titan so I bought a Gen-Y hitch adapter. Works great.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
08-04-2017, 03:48 PM
2017 30' International
Broomfield
Hitch drop 2500 HD
Here is a picture of my equalizer setup on my 2017 2500 HD. I'm using 5 washers on the equalizer and the trailer (2017 30' international with about 980lbs on the tongue) sits dead level.
This is a 6" drop shank but as you can see I am not using the 2 bottom holes so a 4" drop should do (for an equalizer hitch anyways...)
08-04-2017, 04:00 PM
Overkill Specialist
Dadeville
, Alabama
That's what I need is the new drop shank of the hitch. Mine is not low enough.
08-04-2017, 04:12 PM
Broomfield
Hitch drop 2500 HD
As you can see the equalizer 6" drop works well as configured in the photo above however there is a small amount of the shank that protrudes below the hitch and reduces ground clearance some...
I may switch to the 4" drop model for a cleaner install and use it on its lowest setting. I have a 3" drop shank and when I tried it out it was about 1" too high....
08-04-2017, 04:18 PM
2000 25' Safari
Denver
, North Carolina
I just changed from a 2007GMC 1500 to 2017 2500 and have the same issue. Plus needing a larger hitch shaft into the receiver. Wonder if I need to use an adapter or new drop hitch. Starting research any additional help appreciated.
08-04-2017, 04:34 PM
Broomfield
Hitch drop 2500 HD
I use the 2.5" -> 2" adapter that came with my truck mainly because (1) it came with the truck and I had it and (2) I already owned a 2" shank so this avoided my shelling out $$ for a new shank.
For what it is worth the 2.5" -> 2" adapter works just fine with my 2" shank.
That being said if you don't have an adapter or are buying a new shank anyways I'd just go for a 2.5" equalizer shank. If you loose the adapter for some reason then you are SOL
08-04-2017, 05:27 PM
2000 30' Excella
Toledo
, Ohio
I use the 4" drop on my 2500 HD with 17" wheels and I bought the 2 1/2" shank . Got it from Etrailer.com $149. shipped . it's heavy when you need to remove it .
08-04-2017, 07:13 PM
Overkill Specialist
Dadeville
, Alabama
That's my worry with the 2 1/2". It being very heavy to remove
08-04-2017, 07:35 PM
Broomfield
Sounds like an adapter + 2" shank is the way to go then it's working well for me.....
08-05-2017, 12:22 PM
1990 29' Excella
Travelers Rest
, South Carolina
____________
Your photo looks just like my 2016 2500HD 4wd Duramax. Same problem, same solution.
+dcasr
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
08-05-2017, 12:31 PM
Tom T
Orange
It's not your imagination. Yes, by the construction & position of the Dodge/RAM trucks, their receivers are 2-4" higher than either Ford F150/250 or the Chevy/GMC 1/2 & 3/4 ton trucks, & they keep jacking them up higher by 0.5-2" at every MY &/or model update.
We've been renting 3/4 ton pick-ups from Enterprise Commercial Truck Rental since 2014, & I had to use a 6-8" drop stinger for my Hensley Cub on my Avion T20 vintage kin, vs. 4" on the 2013-16 F250s (our local ECTR doesn't have Chevy/GMC in stock so far, varies by location) - & our stock drop axle `60 Avion is at +/-18" at the Hensley Cub stinger box top height (it's stock coupler is at 20"+/-)).
Also, all of the truck makers keep jacking up the trucks ever higher every new model, so the new 2017 F250s now require a 6" drop, as well as another friggin 2" higher climb-in & lift-to-bed for us older & for normal folks!
IMHO they all need to stop building all of their trucks for the "Ricky Racer" & "Oscar Off-road" 20-30-somethings that you see drooling over big/tall/boxy trucks on TV ads, who want jacked-up trucks for show - & go back to folks who actually have to use them for work lifting stuff in & out of beds all day, climb in & out for travel, hitching for towing, etc.!
There is at least 6-8" of BS lift height beyond the needed suspension travel - even for 4WD & off-road - that they can eliminate! Just look at all of the excess space above the tires!!
Bottom line, from my measurements of the 2500Hd Dmax at the local dealer, you'll probably need an 8" +/- drop, depending on the coupler height of your trailer.
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
08-05-2017, 12:36 PM
1990 29' Excella
Travelers Rest
, South Carolina
__________
If you go to a 2.5" shank be sure that your ball hitch body that bolts to the shank can accommodate the wider shank. My hitch ball body that fits to either side of the shank and the bolts pass through all of it would not accommodate a wider 2.5 shank....I'd have to buy a ball body for the wider shank....so I'm happy with the adapter.
08-05-2017, 06:47 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
In the Airstream specs, check the height of your TT coupler and compare it to my 2006 35' SOD. My Duramax HD ball height worked out to be 6' drop. Yours could be lower.
guskmg
08-06-2017, 04:27 AM
2000 30' Excella
Toledo
, Ohio
Originally Posted by dcasr
__________
The 2 1/2" shank drop is machined to 2" at least the one I have is .
08-06-2017, 05:14 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I kept my 2" receiver and use the adapter for this reason and because it provides more flexibility should I need to tow with a different truck in an emergency.
@living.somewhere.yonder | Instagram
08-06-2017, 06:12 AM
2000 25' Safari
Denver
, North Carolina
Purchased the adapter and trying it out this week. I already "forgot" it was in there when I was setting up so I'll be cruising for a 2.5 shank. Lucky it didn't fall out moving from one part of the driveway to the other.
I little worried about how loose everything is with the adapter, not tight at all. Normal for some "slop" and rattle?
08-06-2017, 08:29 AM
Tampa
The Equal-I-zer web site has a calculator for the shank size.
Airstreams seem to all be about 19" ball height, so you measure to the top of your receiver, plug in that number, and it tells you if you need a lower shank or what holes to put the hitch in.
They sell shanks, or Curt, E-Trailer, and others do also.
https://www.equalizerhitch.com/find-your-shank-size
08-06-2017, 02:12 PM
Broomfield
Hitch drop 2500 HD
Just put the pin through to hold the adapter in place when not towing. Mine fits pretty well - not too much movement...
