Join Airstream Forums Today
Old 05-25-2011, 09:22 AM   #1
2005 19' International CCD
Wausau , Wisconsin
Ceiling/wall covering
Covering is off-white thickly textured cloth. Good looking when new and clean. Factory replaced under warranty when new in '06 because of the "aluminum/rivet dust created while traveling. (are we suposed to just let the unit sit in storage!?) Black spots are reappearing, so it's embarrassing showing our Bambi to visitors. Entertaining is mostly under the awning, outside, since we (well, one of us) are sort of clean fanatics. Apparently cannot clean with normal processors. Factory has no solution.
easy sawyer is offline   Reply With Quote
Old 05-25-2011, 10:02 AM   #2
Goal15's Avatar
Rowlett , Texas
Is it almost like carpeting or thick upholstery? Have the same thing in our 2006 Safari 23 and have been wondering about how to clean it. Wondered if carpet cleaning would work on it?
Goal15 is offline   Reply With Quote
Old 05-25-2011, 11:37 AM   #3
2002 19' Bambi
Lafayette , California
This subject reappears from time to time. If your only problem is the black spots, you might be interested in this: http://www.airforums.com/forums/f39/...tml#post739769 .
Tim
Tim A. is offline   Reply With Quote
Old 05-26-2011, 01:29 PM   #4
Wausau , Wisconsin
Apparently the spots are the aluminum dust created as the trailer skin flexes against the rivets. So the usual carpet cleaners would only spread the black through the covering fibers, making matters worse.
Old 05-26-2011, 06:24 PM   #5
InsideOut's Avatar
1956 22' Safari
Edgewater , Colorado
Images: 94
Vaccuum???
Shari
RMVAC | WBCCI DenCO Unit | Tin Can Tourists | Sisters on the Fly | BIRDY - our '56 Safari
Old 05-27-2011, 11:09 AM   #6
2002 19' Bambi
Exactly right, the aluminum dust is the culprit, so Shari's suggestion of a vacuum cleaner does not work. The solution I describe in the link above does work because the paint makes the backing of the fuzzy wall covering impermeable to the dust, so the spot does not reappear.
Tim
[IMG] code is Off
Just got a 1966 ALANSD 1966 Overlander 291 05-03-2012 07:04 AM
Removing residue from peel and stick. Help! bendavanza Floor Finishes 3 05-31-2011 08:47 AM
Wall Covering Pictures Roadrunner Upholstery, Blinds, Walls & Interior Finishes 7 05-19-2011 10:50 AM
Ceiling Covering Falling Down RonH General Interior Topics 2 03-08-2011 02:37 PM
