Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 08-18-2019, 08:48 AM   #1
1972 27' Overlander
Columbus , Ohio
City water inlet plumbing
Hi All,
I recently installed a sureflo city water inlet and it says to use high pressure flexible tubing for at least 1 foot before connecting to rigid plumbing. Can anyone confirm that using the same type of braided tubing used for the freshwater tank pump would work? In the instructions it looks like they are using something different so I just want to make sure that would still work. If not can someone please clarify exactly what they think should be used here. Thanks!
action95 is offline   Reply With Quote
Old 08-18-2019, 02:43 PM   #2
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Should be fine with anything from home depot. On newer models the fitting actually attaches directly to the PEX and some people have put a length of flexible tubing in to avoid the 'solid' connection that can cause the inlet to crack and leak. That's on my list, but not high up as I virtually never have hookups, I use the pump even when in a place with water...just keep the tank filled. The shur-flow has a pressure reducing valve in it, but to be safe a lot of people add another at the spigot or at the inlet to be safe.
pcskier is offline   Reply With Quote
Old 08-18-2019, 07:29 PM   #3
1972 27' Overlander
Columbus , Ohio
Sounds good, thanks for the info!
Old 08-18-2019, 07:41 PM   #4
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Their instructions may also be to prevent stress if someone should connect a rigid water filter right at the inlet.
rowiebowie is offline   Reply With Quote
Old 08-19-2019, 02:01 PM   #5
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I believe from my experience residual water in the inlet freezing is the culprit, not PEX flex. PEX is some what flexible and freeze proof.
guskmg
Old 08-19-2019, 02:18 PM   #6
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Be cautious with City Water on when unattended. When we lived on our boat we saw numerous other boats sink when left & sometimes a worker would open the valve at the dock thinking that they were doing you a favor after performing work.
We only use the 12 Volt Pump because of this but then others have no issues.
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Water coming out city water inlet mutcth Fresh Water Systems 7 11-02-2021 03:31 PM
Water leak at city water inlet, not hose connnector EddyBearPS Plumbing - Systems & Fixtures 13 05-07-2021 05:38 PM
City water inlet and potable water inlet replacement sizing? LiamO86 Sprinter and B-van Forum 2 05-09-2019 05:05 PM
No water in fresh tank, but city water inlet still drains out Pat Pierce Fresh Water Systems 1 05-02-2019 04:54 PM
1972 Overlander leaking water city hookup inlet gushing water by bumper Marlin4622 General Repair Forum 3 10-30-2018 07:22 AM
