RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-09-2019, 12:11 PM   #1
City water inlet and potable water inlet replacement sizing?
Hey guys,
I've searched and couldn't find much but in looking to replace my older and brittle city water inlet as well as the potable water inlet on the outside of my '89 B190. Any ideas the exact size, the measurements I found on Amazon don't seem to measure up with what I'm measuring, although maybe I'm taking measurement from wrong place.
LiamO86 is offline   Reply With Quote
Old 05-09-2019, 12:12 PM   #2
Pics attachedClick image for larger version
ID:	340244Click image for larger version
Old 05-09-2019, 06:05 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If there is an RV parts store (Parts66, etc.) or a boating supply store (West Marine, Bass Pro, etc.) in your area, you might try removing the old fittings and taking them with you to get something that is a reasonably close match.
Side note, it's odd that one fitting is labeled "Water Only" and the other "Potable Water Only." They should BOTH say "Potable Water Only." The only difference is that one lets you use city water directly, the other lets you fill your fresh tank with city water.
Where find Thetford potable water inlet (lockable) OregonArgy Fresh Water Systems 8 10-09-2017 02:15 PM
Once and for all--need to blow out City Inlet and Black Flush? pcskier Winterizing, Storage, Carports & Covers 27 12-01-2016 12:38 AM
city water inlet pressure reducing unit - fixing/buying a replacement monkeydance Fresh Water Systems 3 02-29-2016 11:50 AM
City Water Inlet Replacement GlenCoombe Classic Motorhomes 6 05-25-2010 11:39 AM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 07:22 AM
