Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-15-2010, 09:00 PM   #1
Astrodokk's Avatar
Seattle , WA
Radiator overflow bottle cracked '79 MH
Where can I get a new one?
2000 Ford E-350 Super Duty 418ci/6.8L Triton V10 21’ Chinook Concourse XL
Astrodokk is offline   Reply With Quote
Old 04-15-2010, 11:55 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'd be surprised if you found an exact replacement but any generic one will work if you can find a way to mount it.
Good luck, Dan
Old 04-16-2010, 05:03 AM   #3
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I think you can find what you need at Millsupply.com in the Step Van Catalog.
Best supply of cheap chassis parts for P30's.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 04-16-2010, 07:26 AM   #4
raveson's Avatar
1989 25' Excella
1989 34.5' Airstream 345
Hobe Sound , Florida
Overflow bottle
Inland RV keeps them is stock. You do have to drill holes and install the dash light sensors if you have them.
raveson is offline   Reply With Quote
Old 05-09-2010, 04:10 PM   #5
1977 28' argosy moho
scarborough , ontario
Replace...or Repair
I'm cheap (Scottish heritage) so I figured I would try to repair my cracked overflow bottle. If it worked I'm ahead of the game and if it doesn't, I'm no further behind. I cleaned it up then heated a knife with a blowtorch. Then CAREFULLY melt the crack with the hot knife and let it become solid again. It's been five years and about ten thousand miles since I repaired it. So far so good!
Warbs is offline   Reply With Quote
Old 05-10-2010, 10:54 AM   #6
pwhittle's Avatar
1982 31' Airstream310
Alpharetta , Georgia
I used a generic one from Advance Auto that had a wire mounting catge. I was able to bend the wire cage to match the existing mounting points.
Works fine.
Paul
1982 FFC with Motorhome Interior
https://shineee.whittlegroup.com
pwhittle is offline   Reply With Quote
Old 05-10-2010, 10:14 PM   #7
Astrodokk's Avatar
Seattle , WA
The bottle isn't exactly cracked...it's one of the mounting ears at the top of the bottle. The plastic got so brittle that the passenger side ear snapped off, and now it's just hanging there all lopsided. Making a mesh cage for it is an EXCELLENT idea!
Freshwater Overflow Geyser RevBec 1990 - 1993 Excella 5 04-19-2015 12:33 PM
Power Steering Overflow... streamlean Mechanics Corner - Engines, Transmission & More... 3 09-20-2007 08:18 PM
Overflow fr8tshaker Off Topic Forum 6 09-16-2006 10:54 AM
Black tank overflow Robfike Classic Motorhomes 8 09-11-2006 08:06 PM
Toilet Overflow bentguy Sinks, Showers & Toilets 4 07-09-2004 03:07 PM
