03-25-2019, 07:43 PM
#441
1966 24' Tradewind
Kansas City
, Missouri
Furrion stoves
Thanks for dropping the welt off last Saturday, Lee. Sorry I wasn't there to greet you.
On another topic - stoves - what do others think about Furrion stoves? I'm thinking of getting one of the stainless steel models to pair up with an Isotherm Cruise 200 refrigerator.
04-04-2019, 09:53 AM
#442
1966 24' Tradewind
Kansas City
, Missouri
Moving on to more instant matters
Here we can see our Tradewind was clearly underwater at one time. Given the delaminated condition of the veneer, I'm thinking of replacing the doors with 1/4" birch plywood, especially since I was just going to sand and paint the doors anyway. Any other thoughts?
04-04-2019, 11:18 AM
#443
1966 22' Safari
Fredericksburg
In our 66 Safari the doors were in pretty rough shape. Mine were hollow core for weight and veneered on both sides over simple framing. I stripped the veneer off both sides, ran a sander over the framing and re-veneered both sides. I think the edges were painted.
04-04-2019, 06:33 PM
#444
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I just made a countertop out of birch veneer plywood 3/4". The birch was very thin, but well applied and pretty hard. It will provide a smooth, flat surfae for the laminate we are planning on using.
I think your plan makes sense.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
04-05-2019, 07:49 AM
#445
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence
, Kansas
A 1/4" inch sounds a little thin. You should be able to find Birch in 3/8" but the other veeners are very hard to find. If your drawer/door-facing is 3/8" like mine, I have a source for 3/8" with different wood veeners (oak etc) if you should decide to match the original wood.
04-05-2019, 10:33 AM
#446
1966 24' Tradewind
Kansas City
, Missouri
I'm not at the trailer today, but as I recall the original doors are only 1/4". But then, my recall is not what it used to be.
04-07-2019, 12:55 PM
#447
1966 24' Tradewind
Kansas City
, Missouri
After returning to the trailer to take another bite out of the elephant the other day, I measured the thickness of my closet doors. Turns out they are actually 1/2" thick, all except for a one inch perimeter that is only 1/4".
In any event, I decided to just score the veneer with a box knife along a straight edge just above the delaminated part and then remove the bad veneer with a putty knife. It left a very clean edge, which, when sanded, should be barely perceptible under the paint job I intend to apply. Not perfect, I know, but I'm fast approaching the point where I just want to get the thing done (the astute observer would have a good argument that I passed that point some time back). My rationale, perhaps my mantra, is that the perfect is the enemy of the good. But I just want to go camping, not make the pages of Architectural Digest.
04-08-2019, 02:43 PM
#448
1970 25' Caravanner
Incline Village
, Nevada
Slats. well said. get that thing done and begin use. i am with you. tired of looking at mine sitting in a friends driveway. am sure it will turn out and not be noticeable anyway
04-10-2019, 06:01 AM
#449
1968 24' Tradewind
1968 26' Overlander
Detroit
, Michigan
Dale - another perspective is that if you end up not liking the repair it’s a job you can easily access to redo later on down the road. Unlike the frame and subfloor it’s ok to do “good enough” on this type of work. Glad to see you chiseling away. I looking forward to doing the same.
04-11-2019, 08:04 AM
#450
1964 24' Tradewind
Lawrence
, Kansas
Like atomic, I also think it is a good idea to get the trailer to a useable stage and start using it. My experience has been that many things I thought were good ideas were not. Even with using the trailer while working on it, I found I had to revisit early-on decisions with better options. And no one can really tell you what is right for your trailer but you. And you will only know your camping life style after you live it a little.
04-11-2019, 11:05 AM
#451
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
ttbikes
Truer words were never spoken. You can take this one to the bank!
Dan
04-14-2019, 08:20 PM
#452
1966 24' Tradewind
Kansas City
, Missouri
The Tradewind has for sure taken me to bank, for sure. Just got my flooring and telescoping pedestal for the table, which will lie alongside the trailer for the time being, supplying mild inspiration for going forward.
04-15-2019, 08:57 PM
#453
1966 24' Tradewind
Kansas City
, Missouri
flooring in
Made a little progress today. Big thanks to Atomic_13 for advising me to install flooring side to side rather than lengthwise.
04-15-2019, 09:20 PM
#454
1964 24' Tradewind
Lawrence
, Kansas
Looks Good!
04-16-2019, 08:13 AM
#455
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Wow, looks fantastic.
Hittenstiehl
04-16-2019, 07:30 PM
#456
1986 34' Limited
1975 27' Overlander
Conifer
It looks very nice indeed. You installed your floor covering like I installed my belly pan; curb to street, not hitch to bumper.
Does anyone use carpets anymore? I have an acquaintance with a 78 Sovereign that still has the original carpet in it, and it still looks pretty good to me.
Going to the bank frequently is part of the routine of the vintage Airstream hobby. My wife wishes I'd take up gardening instead. Cheaper.
David
04-16-2019, 11:54 PM
#457
1970 25' Caravanner
Incline Village
, Nevada
Floor looks great. And the accent trim on the walls is a good compliment to it
I installed our floor in same manner, but with no specific intent. Curious to know benefit of that configuration as opposed to vertically.
04-17-2019, 12:06 AM
#458
1967 24' Tradewind
North Pole
, Alaska
Same here. Looking forward to your thoughts, and thank you for all the inspiration I get from your thread!
Dan
04-17-2019, 08:45 AM
#459
1966 24' Tradewind
Kansas City
, Missouri
If I recall it correctly, Brian's (Atomic_13's) suggestion was based upon his observation that installing the flooring lengthwise made it more prone to separations at the seams. If I have misspoken, he will gently correct me, in his characteristically courteous and articulate manner.
Thank you for your kind comment, Dan. My progress thus far is more attributable to a sort of naive dogged determination more than anything else, such as talent. I'm going to get this thing done if it kills me, which is may well do, give my proclivity for involuntarily donating blood to the project on a daily basis. Yesterday I sliced my finger with a tape measure, no less.
04-17-2019, 09:54 AM
#460
1966 24' Tradewind
Kansas City
, Missouri
