Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Nest > Nest 2018 - Current
Old 11-16-2020, 09:38 AM   #1
Charlotte , North Carolina
Battery / Controller/ Ground/ Or Sea Level Reading Issues
In this scenario, I am not connected to Shore Power. Running off battery power only with no Solar.
I have two AGM 76 AH batteries. Currently, batteries are fully charged and a handheld meter confirms 12.9 Volts.
*Sea Level Reading bounces between 12.4 and 11.8
*Power to all devices in the trailer will reset after a couple of moments of use and the fridge will turn on but not cool.
Thoughts on where to start in troubleshooting?
PodLife is offline   Reply With Quote
Old 11-16-2020, 11:47 AM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Need a little more information. What year and model is your trailer. Does it have a 12V fridge? Even if you do, your 12V batteries do not have that much reserve power, and running your fridge on 12V will deplete them quite quickly.
The Sea Level gauge is not all that accurate, so I would not rely on that alone to determine your batteries' true state.
thewarden is offline   Reply With Quote
Old 11-16-2020, 05:22 PM   #3
The fridge is 12 volt. Somehow I am losing 1 volt. From 12.9 to 11.9 (both voltages taken with handheld meter) from location of the battery to inside the 2019 Nest. Measuring outside on the battery terminals and inside on the 12v side of the fuse/breaker panel.
Old 11-26-2020, 07:36 AM   #4
love nest's Avatar
2019 Nest
Louisa , Virginia
Battery power
Check this thread. May help. https://www.airforums.com/forums/f54...ng-206034.html
2019 Nest FB
2014 F150 STX 5.0
SS Works long headers & Duel exhaust, Banks Ram Air
5 Star Custom Tune
Louisa, Virginia
love nest is offline   Reply With Quote
See Level II battery monitor reading doesn't make sense runtime Electrical - Systems, Generators, Batteries & Solar 10 07-06-2021 05:55 PM
Sea Level 2 Pthorpe4080 Electrical - Systems, Generators, Batteries & Solar 1 05-01-2018 07:40 AM
Sea level II Monitor Rockhound100 Plumbing - Systems & Fixtures 6 07-08-2017 08:17 AM
Sea Level to High Elevation: Look Out! Ray Eklund On The Road... 21 09-15-2016 10:15 PM
sea level II Drplate General Repair Forum 0 11-09-2015 08:02 PM
