Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 04-06-2018, 03:35 PM   #1
Paul Kukstis
paul.kukstis's Avatar
2018 30' Classic
Scituate , Massachusetts
Problem with safety valve popping between Alde flow and Alde
2018 classic 30 with Alde 3010 and Alde flow
With city water on the valve keeps popping open, draining underneath. Too much pressure ? Faulty safety valve?
Another problem using fresh water - not enough pressure and seems like air pockets still in system. Turn on faucet and you can hear the flow unit bubbling
Any ideas?
paul.kukstis is offline   Reply With Quote
Old 04-06-2018, 05:11 PM   #2
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Any ideas?
Turn off city water and turn pump off. Then manually drain the water, not the Alde fluid, completely out. Could take ten minutes, you can watch it under the trailer. When finished close the relief valve and open the city water. Should be good to go. There is a necessary air pocket at the top of the sanitary water jacket which needs to be maintained or it will dump on its own. I do it once a week to ten days
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 04-07-2018, 01:08 AM   #3
2007 22' International CCD
Or just add an accumulator tank somewhere in the AS cold water plumbing. They have a permanent air bubble in them. Camco makes one...
Old 04-07-2018, 07:07 AM   #4
Paul Kukstis
2018 30' Classic
Thanks for responding so quickly.
Did that - same thing.
Other issue with water pump - will not shut off... adjusted the pressure screw on the unit - up and down - no luck.
Old 04-07-2018, 08:20 AM   #5
Paul Kukstis
2018 30' Classic
Thanks for the quick response.
Tried what u said...same result. If I turn on a hot water faucet, then close the valve, it does not pop again; turn the faucet off, then it pops.
Old 04-07-2018, 07:09 PM   #6
ObviouslyKnot
james.mileur's Avatar
KAILUA , HI
There have been a few Safety valves that were defective. Call JC, perhaps they will provide you a new one shipped out for DIY.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 04-08-2018, 04:50 AM   #7
paiceman's Avatar
What James said. Several have had to be replaced. There is a check valve in the water pump which may have gone as well, mine was replaced under warranty a couple of weeks ago at the factory.
Old 04-08-2018, 06:09 AM   #8
Paul Kukstis
2018 30' Classic
Thanks for the replies...have a call in to JC...going to try an external regulator at 40# to see if that works
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Black Water Tank Valve Open but no Flow... dbaverb Waste Systems, Tanks & Totes 20 07-15-2009 09:19 AM
Is there a back flow valve on my water pump? Mrcrowley Fresh Water Systems 5 04-25-2009 10:06 AM
Shower Regulator or Back Flow Valve GStephens Fresh Water Systems 19 07-08-2004 09:56 AM
