Old 04-19-2021, 07:15 PM   #1
Airstream Coach - Other
Pittston , Pennsylvania
Help with de winterizing 2017 classic 30
Hello all I’m a tad bit confused on what is the normal position of the knobs in the picture during summer operation. This is how the trailer came when I bought it winterized. I only have one yellow relief valve as I’ve see multiples in other threads. My unit is the 3010 alde system. Thanks for any help.Click image for larger version
Lundman is offline   Reply With Quote
Old 04-20-2021, 04:43 AM   #2
Lily&Me's Avatar
Normal , Illinois
There may be a diagram in your owners manual, showing you how these are to be set for winterizing bypass, and then normal use.
I keep mine marked with a little tab.
Someone with the same rig may give you better information, but if not I would call the service department where you bought it.
Good luck,
Maggie
🚐 Interstate Owner Emeritus 🚐
🌹 Cherish and appreciate those you love. This moment could be your last. 🐚
Old 04-20-2021, 05:19 AM   #3
AnnaBelle33's Avatar
2021 33FB Classic
City , West Virginia
https://www.airstream.com/wp-content...manual-124.pdf
Here is your owners manual. My 2021 manual has a good drawing in it about it. I skimmed through quickly but didn’t see one in yours. I can look for mine or check out 2018s - probably the same.
AnnaBelle33 is offline   Reply With Quote
Old 04-20-2021, 06:44 AM   #4
Sag Harbor , New York
A helpful exercise might be to consult as many manuals as possible, then sit at the mechanical space in the photo, and figure it all out . . .
Which pipes do what? [red hot/blue cold?] In what direction is the liquid flowing in each pipe?
Disco here dat go dare?
Where is the water pump? Then continue the exercise . . . where is the water filter between the water tank and the pump?
Could you winterize your new-to-you trailer on your own? If you can figure this out, just reverse the process to "summerize."
Having an Airstream is also a journey of self-discovery and learning.
Happy Trails!
Peter
Old 04-20-2021, 06:50 AM   #5
** PS **
Generally . . . for a valve to be "open" and permit water to flow,
the valve's handle will be in line with the pipe, not perpendicular to it.
----- --O-- -----
Old 04-20-2021, 09:51 AM   #6
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Originally Posted by Lundman View Post
Hello all I’m a tad bit confused on what is the normal position of the knobs in the picture during summer operation. This is how the trailer came when I bought it winterized. I only have one yellow relief valve as I’ve see multiples in other threads. My unit is the 3010 alde system. Thanks for any help.Attachment 393584
Hi
In order to really work out what's what, you need the view in the picture and the view from under the table. Without both, there is no practical way to trace them out.
From memory:
1) This is the hot water into the mix valve. That valve is now turned shut, it needs to be open.
2) This is the bypass valve around the hot water system. It is now open, it needs to be shut.
3) This is the cold water supply to the system. It is now shut. It needs to be open.
Simply put: All these valves are in the "winterize" position right now. They *all* need to change state for normal operation.
4) Is a pressure relief. It does not get played with unless you want to dump the system. I normally leave it "open" for winter storage. It is shut in the picture. If you leave it open, and have water hooked up, you get a big puddle under the trailer .... I have data on this
Old 04-20-2021, 10:22 AM   #7
69SoulShine's Avatar
Bluffton , South Carolina
Looking at mine now and uncle Bob is correct , As usual.
number one is open
number two is closed
number three is open
number four is closed
69SoulShine is offline   Reply With Quote
Old 04-20-2021, 01:05 PM   #8
Isn't 4) also a hot water low-point drain for this area? If so . . . good to know for winterizing the trailer IMO.
And what is the yellow handle partially hidden by 4)? In Post #7 that yellow handle is more visible. A cold water shut-off, or pressure-relief valve?
Thanks.
Old 04-20-2021, 01:10 PM   #9
number one is open
Please ID the yellow handle valve referenced in the previous post.
Thanks.
Old 04-20-2021, 03:01 PM   #10
2021 33FB Classic
Here is mine. 30 & 33 pics attached.
Old 04-20-2021, 05:15 PM   #11
2014 27' Flying Cloud
Stowe , Vermont
I have a rather comprehensive, step by step chart that I made for de-winterizing our 2014 Flying Cloud, 27 ft. Although it is specific for our unit, it may be used as a general guide for many units. If you would like a copy, email me at: sgraner@aol.com
VT Wanderer is offline   Reply With Quote
Old 04-21-2021, 05:25 AM   #12
DeltaRon's Avatar
2015 28' Flying Cloud
2018 33' Classic
Cumming , Georgia
There is a second yellow valve to the left of your picture. You have to remove the left false front to the dinette seat.
DeltaRon is offline   Reply With Quote
Old 04-21-2021, 08:28 AM   #13
Half a Rivet Short
2022 Interstate 24X
Thanks.
Hi
If you happen to pull up to a campsite that has 100 pound water pressure *and* you have the original stock regulator on the trailer (that's set to 60 pounds) ....
You will find that the gizmo with the yellow handle is a pressure relief that goes off at 55 pounds. You get a big puddle of water under the trailer.
Indeed it can also be used as a low point drain. That's why I leave it open as part of the winterize process. It's primary function is to protect the 3010 from over pressure.
Old 04-21-2021, 09:24 AM   #14
Thanks Bob, but isn't the black-handled valve -- labeled 4) in the OP -- a separate LP drain for that red hot water line?
The yellow handle is on a different valve per the photo in Post #7, but is mostly hidden [by the black handle] in the OP's photo IMO.
Old 04-22-2021, 07:08 AM   #15
Half a Rivet Short
2022 Interstate 24X
Hi
Keep in mind that I'm going from memory here ....
My recollection is that the yellow is the overpressure, could be wrong.
Old 04-22-2021, 08:01 AM   #16
Looks like that in the referenced photos IMO.
Just trying to make clear for the OP that the 4) black handle on the red hot pipe is probably a true low point drain, which needs to be open when winterizing with compressed air.
Helpful info for future readers too.
Winterizing / De-Winterizing Adventure.AS Winterizing, Storage, Carports & Covers 18 11-03-2021 01:28 PM
De-winterizing with my new winterizing kit installed PatLee General Interior Topics 12 01-23-2020 05:55 AM
De-Winterizing & Winterizing after short trip to TX Jasper14 Winterizing, Storage, Carports & Covers 6 01-20-2020 02:31 PM
Winterizing 2017 Bambi. We just Mostrander 2005 and newer - Bambi all models 5 01-04-2017 05:19 AM
2017 Grand Tour Winterizing bob323 Sprinter and B-van Forum 17 11-24-2016 08:27 AM
