Originally Posted by lsbrodsky
There are other reasons AGM's are better for our needs, but chances are good that you will cook regular flooded cells on solar.
I beg to differ... I am not familiar with the latest models, but previous AS models were notorious for cooking the batteries because the converter/charger would overcharge the batteries or not progressively charge them according to the battery manufacturer's specs which needs to take into account battery temperature.
I use my MPPT solar controller to charge my batteries (365 days per year) and not the trailer's converter/charger. To do this, I put the Use/Store switch in Store position when connected to shore power which cuts off the batteries from the converter (while leaving them connected to the MPPT solar controller). If your unit is not wired in this manner (it depends on the year/model), you can have your dealer make the ajustment.
In that situation the rest of the
12V circuit is fed from the converter. If I do need the charger (in which case the MPPT controller is generally not supplying any or little charge because of too little sunshine), I will switch to Use mode, but cut back to Store mode when the batteries are 85% charged, and then let the solar system complete the charge properly.
It's been over two years that the solar system has been maintaining my 4 deep cycle 6V lead acid batteries and I have not had to add a single drop of water in any of the 12 cells.
It depends on the charging parameters of the MPPT controller, on the capacity of the battery bank compared to your power usage and the capacity of the installed panels. If you are regularly depleting your battery bank because it is undersized relative to your power usage and recharge it with high amperage without consideration for battery bank temperature, you will have gassing (hydrogen), heating batteries and water loss. Today's programmable MPPT controllers are pretty sophisticated and I trust them more than the OEM controller in my Airstream to properly maintain my battery bank. And if your solar system is properly sized and configured, you can pretty well forget it and let it do its job, even with lead acid batteries.
