Old 10-12-2020, 12:04 PM   #1
Lexington , Kentucky
Batteries dead on “new” classic 33?
We took delivery of a 2020 Classic 33 from a major NE 5 rivet dealer first week of August. Since then either while camping or while outfitting at the house we have been on shore power most of the time or off shore power and locked up. Had noticed something was up when off shore power - no lights would cone on and czone panels all over trailer would blink on and off. Voltage of batteries on Victron display showed voltage of 3V or even less. Plugged in to shore and display shows 13.6.
The word “new” is in quotes because I was able to find out that my unit was manufactured in November of 2019 so it means probably sat on lot for many months. I am ok with that - just wonder if batteries were maintained at all? Czone had several alerts back to December and throughout the year ( batt low voltage) and given my noco charger does not seem to revive them I suspect they are ruined? (And may be outside or nearly outside mfg (Lifeline) 1 yr warranty.
Given solar and shore power is working (they are) - I guess I have to go through hassle of removing and taking them to a Lifeline dealer.
Any other thoughts or comments?
ocropper is offline   Reply With Quote
Old 10-12-2020, 12:51 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
How about a simple approach assuming traditional lead acid batteries.
Remove the batteries and use a simple charger and try to charge them. If they don’t take a charge, not a good sign.
If you can get a charge into them take them to a local auto parts store and ask if they can test deep cycle batteries.
Limit the back story about the batteries.
Or if the batteries have removable caps a hydrometer can tell charge health.
If you have other than lead acid other folks can advise.
Then you can test review convertor status.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 10-12-2020, 12:53 PM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
If you have solar you should have AGM not wet cell and your solar should have kept the AGM charged. Can you confirm this is the case that you’re talking about AGM?
Should be covered under warranty. Have you tried reaching out to the dealer?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 10-12-2020, 01:14 PM   #4
2018 25' International
Slidell , Louisiana
To add to the already good guidance, given that your Noco, I assume Genius, Charger did not revive them and they show less than 6 volts on their own, clearly symptoms that one or more cells are dead shorted. Isolated or removed, confirm you are unable to get them to take a charge by trying once more and then replace them, hopefully under warranty. Sorry for your troubles.
Brian
Old 10-12-2020, 02:53 PM   #5
jaybauman's Avatar
2021 33FB Classic
2019 30' Flying Cloud
Katy , Texas
To be reading those low voltages, you have likely dropped a cell (or two or three...). Lifeline AGMs have a 5-year pro-rated / 1-year replacement warranty. I have non-RV experience with these guys, and I find they really stand behind their products. In the worst case, you'll be out 20% of the replacement cost. But between Lifeline and your 5-Rivet dealer, you might find a way to get made whole. Just be sure to ask nicely.
2021 Classic 33
2020 GMC 3500HD Duramax AT4
ProPride 3P
jaybauman is offline   Reply With Quote
Old 10-12-2020, 03:00 PM   #6
Yes they are AGM. And Solar is generating enough most sunny days to charge them well. I think like others have said I have bad cell(s).
Old 10-12-2020, 03:03 PM   #7
Thanks. Yes I have noco genius 3500 so I think it would do the job if batts were good. It maintained the AGMs in my prior trailer well. Thanks.
Old 10-12-2020, 03:48 PM   #8
GCinSC2's Avatar
Sorry most of my .02$ applied to old non solar systems.
Like what I have, a simpler rig.
S/OS #001
Old 10-12-2020, 08:32 PM   #9
2018 30' Classic
So your batteries died with the working solar system or is something else failing that is causing the batteries to die?
BigSxyWhtGuy
Old 10-13-2020, 06:51 AM   #10
An update from this morning and thinking about it over night. I found my multimeter and took voltage readings across any combination of the battery terminals with shore power off - 12.83V - sounds like batteries are in fact good. The Victron shows 13.6V for batts when shore power on, when I pull the plug shows 3.2V (and constantly fluctuating).
Is it possible that the batteries are not ‘engaging’ when off shore power and if so what would cause that. Btw, if plugged into shore power and I use the app (or the button) to battery disconnect most items power off (except for microwave clock for instance).
Any new ideas? I honestly believe the batts may be good, how else would I get the 12.83V reading?
Old 10-13-2020, 08:33 AM   #11
Slidell , Louisiana
Edit: Indeed if the battery resting voltage is north of 12.8 they are in very good shape.
There are resetting thermal breakers on the battery bus bar which protect the battery cables and the primary side of the power distribution center. They will generally be 50 amp but may be more if the converter plus solar exceeds 50A. There are two, one on the battery lead cable and one on the power center load cable which normally ties to the solar charge controller and converter and Use/Store relay together, then goes on to the power center. Perhaps one of these breakers has tripped and won't reset. Some reset manually with a little button on them, others are supposed to reset automatically, but sometimes require all voltage from both sides be removed.
If they are 50A, it is possible one tripped if the battery was severely discharged and solar plus converter exceeded the 50A limit.
Brian
Old 10-13-2020, 08:54 AM   #12
2021 23' Flying Cloud
Hansville , WA
New guy here: We just received our 2021 23 Flying Cloud FB. It came with First Interstate batteries. Been thinking about solar addition. Why do you need AGM batteries if you get solar?
Big Red1 is offline   Reply With Quote
Old 10-13-2020, 09:09 AM   #13
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
If you have solar, your batteries will be charging all the time every day, during daylight. Most people are not willing to put in the time to monitor water levels as frequently as would be required. AGM's are much more user friendly and can handle some "neglect". There are other reasons AGM's are better for our needs, but chances are good that you will cook regular flooded cells on solar. However, that is not the case if you want to take care of your batteries. Really not worth the effort for the price of upgrading to AGM's
larry
lsbrodsky is offline   Reply With Quote
Old 10-13-2020, 09:15 AM   #14
Slidell , Louisiana
The solar chargers change the game since you no longer have to purposefully do something like plug into shore power or add an external charger or completely isolate the batteries to maintain a charge (it is very important not to let the resting battery voltage go below 11.5 volts, you should not let them drop below 12.1 really). All you need to do is ensure there is sun on the panels, so the normal process of regularly checking water level tends to get neglected. AGM batteries do away with water loss unless you severely abuse them. Also the cyclic nature of charging and slightly draining promotes water loss in wet cells so it is a double whamy. Finally since the sun is only full strength for about 6 hours a day, it is not long enough strong charge to prevent sulfacation of the battery and wet cells have this issue. After a couple few months, an external charge at 14.6-14.8 volts for 12-14 hours is required for wet cells that received the cyclic charge and drain, really once a month is best. AGM batteries have this issue to a much lesser extent, so the external charge requirement is reduced, though once every 6 months to a year is required if the battery cycles.
So if you continue to regularly check water level and get an external equalization charger, no need for AGM batteries with solar.
Edit: What Larry said, he beat me to the punch.
Brian
Old 10-13-2020, 09:21 AM   #15
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You need to check the use/ store switch and the main disconnect switch as well. There is no 100% guarantee that they are hooked up right, even if they are in the correct positions. A quick poke with your multimeter will confirm they are doing ok.
Next past that quick guess, start tracing the battery voltage back from the battery towards the main part of the 12V wiring. As mentioned above, the battery hooks into a 12V distribution bar. From there it heads into the switches and relays I mentioned above. After that it gets to the 12V breaker panel. All of this is shown (somewhat crypticaly ) in the later part of the owner's manual.
Fun !!!
Old 10-13-2020, 10:37 AM   #16
I appreciate your help. Where specifically might this be - the breakers. I assume these are not the ones located in breaker and fuse center under the dinette?
Old 10-13-2020, 02:37 PM   #17
Slidell , Louisiana
They are not, and I don't know where exactly where on the 33' trailer it is. More often than not they are in or near the front curbside corner of the trailer or somewhere between that corner and the location of the power center. Sorry I can't be more helpful.
Brian
Old 10-13-2020, 03:26 PM   #18
2020 Classic 33
Box Elder , South Dakota
Ocropper, when you used your multimeter were you outside in the sun? If so, and assuming you didn't disconnect the battery cable from the Victron Solar controller, then you were likely reading the output from the panels. To check the batteries without removing the solar cable, they are labeled and not hard to do, do the check after the sun goes down, CZONE system turned off, and disconnected from shore power.
For others, the latest Classic 33 does not have a store/use switch. CZONE controls the 12V with an on/off button. Bus bar is different without the resettable breakers. There are massive MRBF marine fuses on a positive bus bar located on top of the batteries. And for those that have this setup order a spare set (1 ea 50 and 100 amp). If they blow you won't likely find them anyplace local (been there and done that). Amazon has them.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 10-14-2020, 10:42 AM   #19
I actually found the fuses on the bus bar. 50 amp one “seems” to be ok - I took off and tried direct hook (I ordered on line some backups to add to my fuse collection). Was hoping when bypassing fuse temporarily it might fix. Unfortunately not.
Old 10-14-2020, 11:43 AM   #20
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi ocropper,*
Please send us a direct message with your contact information, email and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Optima Batteries Dead - '03 Classic Joe Z Electrical - Systems, Generators, Batteries & Solar 7 04-13-2021 07:20 AM
<2mo Old - Dead Batteries Dead Electricals GT2018WA Electrical - Systems, Generators, Batteries & Solar 9 05-29-2018 01:48 PM
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 12:36 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
