08-09-2017, 07:27 PM
2017 27' International
Lewes
, Delaware
Are You on the Level?
Would appreciate recommendations on a good all around product to use for leveling a 27FB International. The more reviews I read of the various products, the less confident I am in any of the products.
Anderson 3604 sounds good, but too narrow and too slippery
Most plastic blocks, crack quickly
Rubber blocks deform and are too slick, don't interlock
Utility Block seems like the best based on my modest research
08-09-2017, 07:34 PM
1974 27' Overlander
Baltimore
, Maryland
I really like my Anderson levelers. Never had a problem with them being narrow or slippery. They're the same width as the tire treads, and it's not like you have to hit them from 40 yards away. I just plop them in front of the tires, give them a little kick to make sure they're snug against the edge of the tire, and drive forward until I'm level.
08-09-2017, 07:49 PM
1995 25' Excella
xxxxx
, xxxxxx
Love my Anderson's.
08-09-2017, 08:06 PM
Oswego
I like.the Anderson's as well. I do occasionally have them slip, so I got some rubber garage floor squares from HD and cut them down to be used under the Andersons.
-Rich-
08-09-2017, 08:36 PM
The Tin Man
SoCal
+1 for Anderson levelers. They are fantastic.
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
08-09-2017, 08:52 PM
2022 25' Flying Cloud
NCR
, Ontario
get a level mate pro 2. we love it
level the trailer once . next time just open the app
1. balance left to right
2 balance front to back
https://www.logicbluetech.com/
- 2nd Generation with ON/OFF switch now shipping!
- Disconnect from hands-free vehicle Bluetooth® system not
- required.
- Energy efficient design.
- Accuracy to 0.1 degrees.
- Convenient snap-in battery holder.
- Easy to install and simple to use.
- Works with most Apple® or Android® smartphones and tablets.
08-10-2017, 11:14 AM
2017 23' Flying Cloud
Parker
I have the Anderson levelers and level
Mate pro described above. Great combo and works well. Highly recommend.
Troutboy
08-10-2017, 11:15 AM
UnklJoe
2015 28' Flying Cloud
Box Elder
, South Dakota
Love My Anderson Levelers, too!
I bought a pair of them, and they came with rubber strips, which I assumed were to be used on wet grass under the main part of the leveler.
I guess they could be used on top of the leveler if someone were worried about a wet tire slipping off.
I was skeptical at first, but even the wife says they're the easiest things about settling in to a campsite.
Didn't like using the plastic squares at all. I now put them under the leveling jacks just to keep them from getting muddy or bending on uneven soil.
08-10-2017, 11:16 AM
SipStreamer
2010 20' Flying Cloud
Lakeside
, Montana
Two, three boards. Different thicknesses.
08-10-2017, 12:01 PM
Long time owner
2004 25' Classic
1974 25' Tradewind
1970 21' Globetrotter
1975 26' Argosy 26
Forrest City
, Arkansas
Back in the mid seventies I cut a 2X8 board into three pieces - 3 foot, 2 foot, and one foot. I screwed these together forming a stair stepped ramp. I made two of these. Now, 40+ years later I am still using them. Cheap and easy to use.
08-10-2017, 12:02 PM
1977 Argosy 28
Euless
We've been using a set of Lynx leveler blocks for almost 4 years and they are still fine. They were used and came with the trailer and we've camped over 170 days in that time.
Past President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath (CA made) and 2015 Ford F250 6.7 diesel. Used to own 1978 Argosy Minuet 6.0 and 2013 Toyota Tundra
08-10-2017, 12:09 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
I'm in the camp that uses a few blocks of 2x8's cut to different sizes. Cheap to replace if needed and have worked well for years. Also the easy way to remove a tire along the road.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
08-10-2017, 07:29 PM
Lewes
, Delaware
Thanks to all who contributed
I went ahead and ordered the Andersons
By the way, I had been using 2x8s in a stairstep for my Sprinters. It did work very well, however, no place to store them in the trailer, and a bit heavy and awkward.
08-10-2017, 08:02 PM
1987 32' Excella
Sagle
, Idaho
Yeah, this one here is the way to go. Go simple, forget the high price crap
08-10-2017, 08:16 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Yes all you need is some scrap wood, 2x8s and a few pieces of plywood.
08-10-2017, 11:47 PM
2007 22' International CCD
Corona
Meh, I just level fore and aft, put the bed pillows on the high side...done!...
08-11-2017, 07:38 AM
2015 25' FB Flying Cloud
Charlotte
, North Carolina
Combination Levelers
I found that the Anderson levelers do not work well on wet grass or soft ground. The offset is that they are easy to use and provide incremental adjustment. My solution is to carry one 2x10 approximately 4 ft long. If needed, the 2x10 goes under the tires on the low side and then the Anderson levelers are added if more adjustment is required. If on pavement or compacted gravel, the 2x10 is not needed. I also added non-skid tape to the working surfaces of the levelers.
08-11-2017, 09:42 AM
2017 27' Flying Cloud
Box Elder
, SD
With duel axels and the Anderson levelers can one change a tire?
Larry
08-11-2017, 09:47 AM
1974 27' Overlander
Baltimore
, Maryland
Larry
The Anderson levelers don't lift my wheels far enough to change a tire. I have a separate tool for that.
08-11-2017, 08:34 PM
Parker
Larry
I have used one to remove a tire on dual axels. You have to get it on the high end and it can be tricky, but it can be done., at least on a 23.
Troutboy
