Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 02-08-2021, 08:49 AM   #1
Miami , FL
Pitting/Chafing around electrical plug
Hello All, Newbie here and I'm looking at a 2010 with some pitting/chafing around the rear electrical plug in. The owner mentioned this was due to the electrical current. Is this common? Should I be concerned? How easy or difficult is this to fix?
Thanks for your help.
Oyekim is offline   Reply With Quote
Old 02-08-2021, 08:58 AM   #2
Kevin245's Avatar
My initial guess would be galvanic corrosion, but it could be something different. Without seeing it we can only speculate. Do you have any photographs?
William C. Swinney
Old 02-08-2021, 09:09 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Are you seeing oxidation/corrosion on the aluminum skin around the plug?
Need pics.
GCinSC2 is offline   Reply With Quote
Old 02-08-2021, 09:50 AM   #4
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
I agree with Kevin, hard to tell, but sure does sound like corrosion. If you can share a pic, folks here could tell pretty quick.
IIRC units around 2010ish had some issues that sounded similar around the running lights. Not inconceivable that the issue was limited to the running lights alone.
panamerican is offline   Reply With Quote
Old 02-09-2021, 05:21 AM   #5
Miami , FL
Sorry, I don't have any pics. Caught it during a walk through and it's not shown on the original pics. After doing some research, I conclude that it was plugged in for a long period of time without proper grounding which caused the pitting to occur. Thanks for your response.
Old 02-09-2021, 06:51 AM   #6
"Cloudsplitter"
Welcome Aboard👍
Like this?
Make sure the plug,(male&Female) clean & tight, use dielectric grease regularly. Make sure everything is off in the AS, including the converter/charger, to prevent sparks when connecting.
Old 02-09-2021, 10:05 AM   #7
PecanMan5's Avatar
2015 25' Flying Cloud
Hahira , Georgia
I have the beginnings of filiform around my receptacle.
From my Pecan Tree
PecanMan5 is offline   Reply With Quote
Pitting and Rust JBeilfuss Stoves, Ovens & Microwaves 1 11-22-2007 08:12 AM
Oven door, pitting balrgn Stoves, Ovens & Microwaves 3 07-21-2007 06:54 PM
Pitting Removal? 05ModPod Cleaning, Stripping & Polishing 3 06-02-2007 11:11 PM
Aluminum pitting on panels kenny Cleaning, Stripping & Polishing 3 02-19-2005 01:12 PM
