10-22-2017, 11:47 AM
#41
2017 19' International
Rosemere
, Quebec
Originally Posted by JBBeaubeaux
Very nice post thank you, is the same wheel and tires recommended for a 19' and does it fit ?
10-23-2017, 08:23 AM
#42
2001 30' Excella
Full-time traveling
, Hmmmm. what day of the week is it?
I would call Vinnie
I suggest you call Vinnie and ask him. He is one of the kindness and generous men you will ever met and he will gladly give you advice, at no charge.
His phone number is : (707) 978-0356
Tell him Jim Beaubeaux suggested you call him. And tell him hi from us!
10-24-2017, 10:55 PM
#43
Washington
, Missouri
Originally Posted by OTRA15
Time to make the swap to 16" Sendel wheels and Michelins before the next major trip.
Happy Trails . . .
Peter
Peter, have you abandoned the 15" options of the GYE's, Nokians to save on the rim upgrade???
I'm still undecided on the GYE/Nokians and will make my decision in the spring when I upgrade but have landed on the 15" side of the coin.
04-10-2020, 05:24 PM
#44
1968 26' Overlander
CORDOVA
, TN
I had biased ply tires on my Airstream when I got it, and they looked vintage...but they suck.....they were rough, and did not flex well at all...
I had a set of takeoffs that came off my jeep cherokee, 15' all terrain radials, with much higher speed rating and weight rating, and they crawl over rough surfaces, compared to those bias plied tires......during the switchover, I observed that one of the bias plied tires was separating in the center of the tread...typical.....bubye.
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
04-11-2020, 06:33 AM
#45
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Exactly what you want...flexible trailer tires, especially the sidewalls.
04-11-2020, 07:23 AM
#46
palm beach gardens
Originally Posted by goliad1
I am going purchase 27 ft flying cloud. Read about people going with 16 inch wheels. What are advantages and the science of doing this? Disadvantages?
Larry
I have many miles on my 16" Sendel wheels and Michelin LT tires. Total piece of mine at highway speeds. Do add tire monitors, any tire can have a problem.
04-11-2020, 01:07 PM
#47
2013 31' Classic
billings
, Montana
Now that gy endurance has proven itself..it may be the way to go with 15”..my 16 michelins have been good..but there is no warrenty from Costco...30,000 miles they developed crackes in bottom of the tread...28%wear....30,000 miles. Got 50% help installed new set...if these don’t do any better than that..I am going to gy endurance..225/75/15...at $70 less money each...
04-12-2020, 11:09 AM
#48
Ravenna
, Ohio
I hope you have been adjusting for the different load capacity of LT type vs ST type. Same with 15" vs 16"
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
04-12-2020, 11:32 AM
#49
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
Goodyear Endurance E rated on 15inch rims
Originally Posted by Mrjkq
16in Michelin LT tires come with an E load rating, ideal for Airstreams. The 15in are not load rated that high & considered to be passenger car tires, some on this forum use them with success. It's your call!
ST 225/75R15 Goodyear Tire Endurance is E rated great tire no problems
Spec Load range E Radial special trailer tire 10ply, 2820 lb max load @80 psi
Great Tire
Laurence
04-12-2020, 11:43 AM
#50
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Originally Posted by AnnArborBob
Lot's of good information in the above posts. Bottom line, 16" wheels appear to give you more options for the tires than do 15" wheels.
And that about sums it up! As mentioned, the older GY Marathons, had a bad track record...folks switched to the Michelin LT's but when Michelin stopped making them in 15" LT rated, several years ago, many folks moved to the 16" wheels so they could run the Michelin LT rated tires which were available in 16"...now, Goodyear has a US made Endurance tire, that many of us use on our 15" wheels, and AS as well as many, many, other TT brands, offer these Goodyear Endurance tires standard. I have had now for 2 years, and love them! When I did put a set of Michelin 15" "P" rated tires on my 2012 25's, I could feel a slight "rolling" sensation when cornering which I did not like. The LT versions I had prior, never had that feel. As I said, I like the new GYE's for 15" wheels.
04-12-2020, 11:58 AM
#51
2013 30' Flying Cloud
Greenwood Village
16" wheels are very nice and if you can swing it, I would suggest the Michelin Ribs tires, they are awesome, wear nicely and have tow very nice
04-13-2020, 08:27 AM
#52
2017 20' Flying Cloud
Ojai
I’ve switched over to 16’s as well. Went with Yokohama 10 ply E rated. Apparently a lot of folks are using them on heavy horse trailers with good success. Also added the Dexter 3” lift. Great improvement in clearance and, no, I have not seen any appreciable difference in handling.
