Old 07-14-2010, 08:25 PM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
Towing a 34ft airstream
Hello to everyone here on the forum.
im sure this question has been asked many times before and i apologize for not finding the answer.
we sold our '66 tradewind last winter and now we are trying to find a 34ft camper. either excella or sovereign with the rear queen bed.
my question: will it be a problem to tow a 3 axle airstream with my truck ? i drive a 2004 F250 with the 6.0 diesel. 4 door and shortbed.71k mls, 2wd.
i'm concerned of not having enough truck / wheelbase to pull this trailer.(sway of trailer on interstate?)
what is your experience? and are their any upgrades necessary to my truck ?
submariner is offline   Reply With Quote
Old 07-14-2010, 09:01 PM   #2
Cantrell's Avatar
1985 34' Limited
1960 24' Tradewind
Summerville , South Carolina
submariner,
Welcome to the forums.
What is the tow capacity of your F250?
It should be more than enough and the wheelbase is fine.
Our 34' is about 7000# dry and it sounds like you are looking for something in the same weight range. We have found the 34 tows and tracks exceptionally well and I enjoy towing it--very stable.
Proper weight distribution set up is a must though. Many threads on the forum addressing what you will need there.
Good luck and let us know what you end up with.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 07-14-2010, 10:23 PM   #3
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
Thumbs up
We tow with an Excursion V-10 4x4 and use "E" rated tires at 75 lbs. front and 80 lbs. rear. Out west I have had no problems but E rated tires are a must. Your wheel base should be close to mine. Also with 6 tires on the road it tracks very well at 60 mph and I get 11 mpg. Good luck to you.
Bing-Bing is offline   Reply With Quote
Old 07-15-2010, 11:50 AM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
It shouldn't be any problem. I tow ours with a 2009 F150 5.4L gas.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 07-15-2010, 12:14 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Good to see another Squid on the Forums. You'll have no problem towing with your truck at all. I owned a 2003 Excursion with the 6.0L PSD and never ceased to be amazed at the pulling power of that truck. Your wheelbase is also excellent. You'll still need a good weight distribution/anti-sway hitch. If you have the money go for a Hensley, if you don't have the big bucks go for the Equal-i-zer or Reese Dual Cam.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-15-2010, 12:44 PM   #6
Central , Mississippi
...my question: will it be a problem to tow a 3 axle airstream with my truck ? i drive a 2004 F250 with the 6.0 diesel. 4 door and shortbed.71k mls, 2wd.
Hello from central Mississippi and welcome to the forums!
We tow our 34' with a 2006 std bed 4 door Dodge diesel, 2wd...no problem. You will need some pretty good weight distribution equipment and the best $9 + you can spend is a trip to the scales.
http://www.airforums.com/forums/f238...-in-17984.html
If you can spring for a Hensley hitch or a ProPride, it makes for a very sweet towing combo.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 07-15-2010, 01:36 PM   #7
Crusty's Avatar
1992 34' Excella
Diesel F-250's do a fine job of pulling 34' Excella's.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 07-15-2010, 03:01 PM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
You have plenty of truck. As mentioned before, spend a little time setting up your hitch of choice and some windshield time in the slow lane getting familiar with your new rig. And, enjoy the extra indoor space.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 07-15-2010, 03:35 PM   #9
2000 34' Limited S/O
Greensboro , North Carolina
Your truck is more than adequate. You will also enjoy the layout of the 34 as well as the ease in towing. I think most of the caveats on 34s are from people who have never owned one. I think an anti sway hitch like a Hensely is a must.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 07-15-2010, 03:57 PM   #10
2010 27' FB Classic
N/A , Texas
I have no experience with towing a 34 but I have towed other size trailers and find that a dually is hard to beat for towing anything. There is very little sway and not much bothers the truck with 4 tires on the rear axle. You never feel like your trailer is pushing you around.
I have towed with non dual wheel vehicles and there is a world of difference between the two.
Just try one and see for yourself.
Old 07-16-2010, 12:50 PM   #11
1978 31' Excella 500
Goose Creek , South Carolina
As others have said, you will be fine.
Holzarbeiter is offline   Reply With Quote
Old 07-16-2010, 06:08 PM   #12
submariner's Avatar
1948 22' Liner
1989 34' Limited
thanks guys for all those quick replies. looks like i should be ok.
now the only problem i have is still trying to find a 34ft airstream in the right price. i can tell you guys, i sure miss my last airstream
Old 07-20-2010, 10:56 AM   #13
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
I just saw a 1990 posted at Top of Georgia. The price looked good as well. PM me if you want more info.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 07-20-2010, 12:14 PM   #14
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
I don't think you will have any problems towing with the TV you spec'ed. The triples sway very little (for me, never the first indication in 41000 miles) always rock steady even in very windy conditions. I use an old reese hitch with friction sway controls and have never felt unstable or in need of a $2500 hitch for the rig.
Whats important to me is to adjust the tongue weight and weight distribution per the instructions.
Check your trucks factory hitch for suitability for a 1000 lb tongue weight and 10000 load and upgrade that if needed.
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 07-24-2010, 03:51 PM   #15
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
I have a 2000 v10 F250 Crew Cab 4x4 - all factory equipped. My only problem is finding a drop shank that will allow the ball height and trailer coupler height to match as needed. Still trying to find the right combo. Good luck - the 34' is a nice rig!
Air Cid
2000 F250SD Crew Cab 4x4 V10
Reese WD Hitch
tvanwave is offline   Reply With Quote
Old 12-15-2010, 08:38 PM   #16
cms4140's Avatar
Birmingham , Alabama
What to expect
After the holidays I plan to list my current 25'er for sale here on the classifieds and get something bigger.
I have been working with a dealer this week on an order for a 30 Classic Limited (twins). However, they have a 34' on the lot with twins, and are getting pretty aggressive with pricing here at year-end.
While I believe I now have plenty of TV (F250 crewcab with 6.4 PSD), I am concerned about the overall towing experience with the additional approx. 4 ft and the third axle. I have read about the rear drag issue, etc. But what else should I expect in the towing experience in going from a 25' to a 34'? And/or, what would be the difference in what I plan to purchase in a 30 CL versus the 34'?
Would appreciate any insight.
Chris
cms4140 is offline   Reply With Quote
Old 12-15-2010, 10:04 PM   #17
_
hi chris
we've had several long thread discussions of the virtues n vices of owning a 34, and compared to 30/31 or smaller.
providing one has an adequate mule here are a few points.
-backing into sites requires pulling FORWARD more, before initiating the reverse/turn...
-the rear end swing will be more obvious with a longer stream.
-the tires will 'roll' or scuff a bit on tighter turns.
-there is the issue of maintaining 6 brakes, hubs, tires n rims.
-often ANOTHER set of leveling blocks is needed (i carry 3 sets)
-rear overhang/drag can happen but simply adjusting approach angle or going slower, often solves this.
-there are 'sacrificial rub rails' at the rear, so USE THEM! (i've dragged 4-5 times in 100k miles towing)
-one must be AWARE of filling stations and tight spots, i use the trucker lanes 90% of the time.
-one can always UNhitch if needed (to get fuel or explore a campground in advance)
-everyone worries about the INSIDE corner and scraping, but the tail swings W I D E, so outside clearance matters too.
-i doubt that there is much (any) appreciable difference between dragging a 30 or a 34.
u will notice the UPsize going from a 25 but adapt quickly.
they are all the same size in the rear view mirrors...
__________
while there is a bit more closet space, galley space and OPEN floor space in the front of a 34,
it's not that much bigger inside and the bathroom layout in the 30 MIGHT be more appealing.
34s and 31 have the entire bath/lav street side.
30s (same size as 31s) have a S P L....I T shower/lav/toilet.
so the bathrooms seems more OPEN in a 30, but the hall way is BLOCKED while in use.
the 34s have a longer narrower hall but showering/toilet use doesn't cut the stream in half.
i really like having 3 axles and the extra/open lounge area...
http://www.airforums.com/forums/f238...ius-21649.html
http://www.airforums.com/forums/f238...lla-40052.html
http://www.airforums.com/forums/f181...rks-41443.html
http://www.airforums.com/forums/f353...6-a-54968.html
http://www.airforums.com/forums/f463...ella-1911.html
i am not a fan of having 2 skylights, which means that much more heating or cooling issues.
u may really WANT a 2nd ac in a 34, especially liv'n in the south.
i get by fine with 1 15,000 btu ac but try to avoid hot/humid locations in the summer.
(vernon--hihoagrv-see post #6 ) went from a 29/30 to a 34 last year and can give first hand views on living with both sizes.
cheers
2air'
Old 12-16-2010, 07:26 AM   #18
cms4140's Avatar
cheers
2air'
2air,
As always, thanks for the reply.
I appreciate the towing experience insight as well as your thoughts relative to floorplan.
I think my mule would handle the 34. However, I am, for whatever reason, extremely nervous about that additional 4 feet and weight (i.e., would I still have adequate tow capacity margin - I don't want to be on the bubble again).
The bathroom layout in the 30 is indeed much more appealing us when compared to the 34 or 31 models. We are not too crazy about the prospect of bathing our small children in such a confined area as those models offer. The split bath set-up makes bathing a 6 and 3 year-old easier.
I can appreciate your feedback on the a/c's. Both the 34 they have on the lot and the 30 I am leaning toward ordering have the 2nd bedroom 13.5k air conditioner.
I don't know. Decisions, decisions...
-Chris
Old 12-16-2010, 08:01 AM   #19
_
Originally Posted by cms4140 View Post
...I think my mule would handle the 34. However, I am, for whatever reason, extremely nervous about that additional 4 feet and weight (i.e., would I still have adequate tow capacity margin - I don't want to be on the bubble again)...
having used an 05 f-250 with the 34 for about 80,000 miles of towing,
and having driven the 6.4 L version u own, the crewcab/short bed 08-250 is very capable.
with the pp as your hitch'n tool that is another bonus.
the weight difference between a modern 30 and 34 is small,
and 3 axles improves support and stability.
it is possible to exceed (or get close) to the payload depending on how much gear is carried in the truck.
i did add 1 leaf spring (per side) to the 250 after 10s of thousands of miles towing...
but your truck is very capable and has the towing capacity for either large stream.
good luck deciding, i am a big fan of ordering EXACTLY what is wanted, when one knows what they want.
but it is nice they decided to make a few 34s this year.
_______
IF the plan is to have the kiddos use the twin bed/rear,
it would be useful for mom/dad to close off the hall doors in the 34,
and imagine using the front 2/3s of the stream after bedding down vs the a bit less space in the 30.
for example, pull out the sofa to the bed position and look at floor space.
then imagine breakfast in the galley/dinette of each unit.
cheers
2air'
Old 12-16-2010, 03:42 PM   #20
I agee with 2air. The 34' triple axle tows like a dream with the right TV and Hensley Hitch. I would not have anything else. I did take out the bathroom wall, see my images, so my bath now reaches from side to side. It's mostly me and my wife, but when we have guests we just close the accordian slide for privacy.
WBCCI #4358
34', towing
NEW: 5th Wheel Airstream Airtrekker Boondocking 43 05-30-2020 09:11 AM
Considering a used Airstream purchase kmb1966 Buyer Guidelines 11 08-30-2011 05:09 AM
Airstream Trailer, Vintage Airstream, Airstream eBay Watch Airstreams on eBay 0 02-10-2011 08:10 PM
Airstream gimlet AirRowan Classic Motorhomes 4 02-02-2011 10:54 PM
