07-21-2018, 02:01 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Test Drive Ford Superduty
Yesterday I took a test drive in a Ford F-250 and a F-350. The 250 had a gas engine and the 350 had a 6.7 PS. I was surprised that it seemed like the F-350 had a better ride than the F-250.
Was it my imagination? Does that seem logical?
I wanted to drive a F-250 with the 6.7 PS but there were none available. Apparently its late in the season for the 2018 models and too early for the 2019 models.
07-21-2018, 02:28 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Therefore a good time to buy?
2019 Ford Expedition Platinum
07-21-2018, 02:31 PM
Alamo Heights
I would expect the ride to be very similar for comparable trucks (e.g. SRW 350, same cab, bed & drive configuration.) The big heavy lump of the diesel probably smoothed out the front axle's behavior somewhat. Until you put enough load on the back to compress the springs down to where the 350's extra leaf comes into play they're pretty similar.
If I were in the market for a diesel superduty, I would get the 350. The cost difference is negligible and the Powerstroke eats a lot of that payload on the 250. I know at least one of the NE states punishes buyers of 350s by forcing you to either register it as a commercial vehicle or outfit the bed in certain ways to make it a camper, I can't remember which state(s).
— David
07-21-2018, 02:35 PM
2019 30' International
Pennsylvania
, Pennsylvania
My guess is the weight of the diesel made the difference in feel. My '17 F250 rides rough empty, but just the other day, I put 320 pounds of salt on the bed and the difference it made was amazing
07-21-2018, 02:47 PM
2018 27' International
Southeastern MI
, Michigan
Maybe a difference in options. They should ride the same. The extra springs don’t come into play unless loaded.
You probably really want the diesel, so it rides better.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
07-21-2018, 03:46 PM
Alamo Heights
He said he drove a gasser 250 and a Powerstroke 350. So yeah, heavy difference in options.
— David
07-21-2018, 04:44 PM
2018 25' Flying Cloud
2024 27' Globetrotter
Jonesville
, Louisiana
I have a F250 with powerstroke rides very smooth
07-21-2018, 08:04 PM
Southeastern MI
, Michigan
Different option levels available for each.
Michelin 16” tires
Hensley Arrow hitch
07-21-2018, 08:09 PM
Alamo Heights
I'm well aware of that. All other things being equal (250 to 250, e.g, just comparing base curb weight) , the Powerstroke weighs about 800 lb more so even with the same options the ride is likely to be different between the gasser and the diesel.
— David
07-22-2018, 09:22 AM
Southeastern MI
, Michigan
The gas engine weighs 580lb. The Powerstroke diesel weighs 920lb. I’ve driven the F350 gas and diesel versions in Lariat crew cabs with similar options very recently and I can say the ride is identical. Both are stickered very close to 3000lb payload.
You can definitely feel the 85 extra horsepower of the diesel however.
Michelin 16” tires
Hensley Arrow hitch
07-22-2018, 09:26 AM
2017 30' International
Lincolnwood
I too have the f 250 with powerstroke. Love the ride.
07-22-2018, 09:47 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you dig into all the various part numbers, there is very little difference between the maxed out F-250 and the "entry level" F-350. There is also near zero price difference. Both have a number of options that change this and that as you tack them on. In both cases the "entry level" truck is a bit different than one with all the capacity enhancing options tacked on. The days of hard distinctions between F-150/250/350 are long gone ....
07-22-2018, 10:49 AM
Alamo Heights
I don't know how much of it comes from the engine itself. However, according to Ford, the curb weight of of the F250 Powerstroke averages 797 lb heavier than the equivalent F250 gasser.
One image is a clip from Ford's website, the other is a spreadsheet made from the data to show the weight difference.
— David
07-22-2018, 11:04 AM
Zionsville
, Indiana
Check with your insurance company before you go to the F350
As previous posters have stated, the F250 and F350 are essentially the same vehicle except for an extra leaf spring on the rear of the F350. That being said, your insurance may not cover the F350 as it is considered by some companies to be a commercial vehicle and they require a different policy - regardless of your intended use. My policy is one such policy (did not know until AFTER purchase) and luckily I didn't go with the F350 - would have significantly changed the economics. As others have stated as well, license plates and taxes may differ for the F350 if the state defines it as a commercial vehicle.
The driving difference is most likely due to the weight of the diesel vs the gasser. My 2017 F250 6.7 PS weighs 5,500 on the front axle alone (CAT scales) and the ride was pretty rough until I changed the shocks to RANCHO 9000 XLs and added Timbren Springs in the place of the factory bump stops all around. The rear Timbrens have yet to touch the axle but the front touch 100% of the time and made a huge difference in cornering stability and ride.
Love the F250 6.7. Tows our 2017 FC26U like it isn't even there - except the factory shocks are crap. If you go that route, just plan on replacing them immediately - only takes an hour to do them all if you are mechanically inclined and have the tools - no jack or lift is required.
Whatever you get, enjoy it and be safe!
07-22-2018, 01:01 PM
2013 31' Classic
billings
, Montana
I did..and bought a ram 2500..with a 6.7.....
07-22-2018, 01:29 PM
Tavares
May I ask why you went that route?
Just curious as I am planning to take a test drive with the Cummins also.
Thanks!
07-22-2018, 01:36 PM
2017 28' International
Jim Falls
, Wisconsin
Thanks!
My son is a diesel mechanic and states the Cummins is the better engine. He says just about all diesel equipment uses the Cummins engine. They have been building diesels for a really long time.
When I finally retire and can camp more that’s my next truck as well.
07-22-2018, 01:53 PM
1972 31' Excella 500
Grapeview
I told my wife I was not going to reply and read only sometime back. Being a RAM owner made a statement and you ask why.
I was a FORD guy for 40 years, big block gasser's no Diesel's. 2 years ago the wife and I went looking for a new TV. We looked at them all, drove them all, priced them all w/what we wanted. We did a lot of research as this would be our last TV hopefully.
Our son is on his 2nd 3500 RAM 6.7. He averages 65k a year. He kept telling us to go w/the RAM.
The best bang for the buck for us was a 2016 RAM 3500 w/6.7 Cummins. We love it.
Best regards and safe travels
Scott & Liz
2017 Classic
2016 RAM 3500 6.7
07-22-2018, 01:56 PM
2018 28' International
Fayetteville
, Georgia
I have been very pleased with the ride of my new 2018 F250 Diesel. Great ride, tows my Serenity 28 with ease.
brick
brick
Cute wife...
07-22-2018, 02:40 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If your ride comfort and better trailer damage prevention is a concern, I would recommend a Kelderman air suspension system. I believe full air ride is now available. I have had a Talon air ride on my '07 DMax for 9 years and am quite pleased with the ride comfort. During that time I have gone to Alaska and back. So far, only 3 rivete have popped. My wife think the truck rides better than our passenger cars.
guskmg
