Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-04-2005, 02:52 PM   #1
Thumbs up How to tighten loose pocket door?
Hello, Our 73 Argosy's pocket door is loose where it hangs from the supporting slide on one side causing the door to hang up due to it being unlevel. How can it be tighten?
Thanks for any ideas.
Terry Koch
tkoch is offline   Reply With Quote
Old 09-04-2005, 04:50 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If it is like the Airstream pocket doors, it is hung by two bolts with sliders and nuts from the top inside the track. Sometimes the nuts back off. If you push the door up from the bottom and then stick your finger down in the track you may be able to feel if the nut is still on the hanging bolt. It is impossible to see. If it is, tighten it. I have not put Locktite on mine. I just tighten it once in a while. If the nut is missing, it still may be laying in the track. If not, you have to quess what the size might be and with some gum on a stick put it back on the bolt and finger tighten it.
dwightdi is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
