Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 05-22-2021, 01:40 PM   #1
2018 20' Flying Cloud
Seattle , Washington
In ground 30/50 amp outlet?
We are building a carport for our FC 20. We need a 30 amp outlet today but would like to Give ourselves flexibility for the future. Do we need to install (and wire) Two outlets or is there a combo outlet that works well?
ssandks is offline   Reply With Quote
Old 05-22-2021, 02:03 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Most folks carry a 50A to 30A "doggone" adapter. That way they can plug a 30A trailer into a 50A outlet. Wiring up a 50A is the only way I know to do both with one outlet.
The wire to get to the box *usually* is the cost driver on these things. It costs by the foot and install takes some work. The box it's self (big or small) is a much smaller budget item (usually). Wiring things up like a typical campsite with a couple breakers and a couple outlets is not a budget buster.
My choice would be to wire in a 50A, a 30A and a pair of 15A outlets. That way you can handle anything that happens along. No digging for this or that adapter. No strange stuff with a 50A breaker feeding 30A wire.
Old 05-22-2021, 02:44 PM   #3
Sag Harbor , New York
Good advice from Bob.
Why not put in a conduit or two, back to your panel area/room, large enough for any and all possible uses, including cable, fiber-optic, telephone, human-tele-transportation/mutation, etc.?
No need to plan ahead . . . ready for all comers . . .
Old 05-22-2021, 03:00 PM   #4
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
There are combo outlets available but we decided on a single RV outlet with a 20 amp plug on the side. It was a 30 but now it's a 50 amp. Mostly I use a dogbone to use the lighter 30 amp cord when in storage.
30 amp copper wire, depending on length of run, is usually #10, whereas 50 amp circuits usually require #6 however #8 has been known to be used. Aluminum wire is different and I would pay for copper and avoid aluminum. Your local Licensed electrician will know which to use. Make sure if you go with 50 amps they know it's an RV outlet, not an appliance outlet. They are wired differently. We had a 30 amp in our car-port originally and had the wire replaced when it was upgraded to 50 amp for our newer AS. Some of this depends on which code and year your local inspector will be using. Many cities today will stay current with national code.
RivetED is offline   Reply With Quote
Old 05-22-2021, 04:02 PM   #5
nryn's Avatar
2019 27' Globetrotter
Driftless Area , Wisconsin
I wired a pedestal—the same kind you find at an RV park. Agree with the above—run conduit and you can pull whatever wire you need through when you need it. Or pull wire for the 50 and swap out the 30A outlet when you want.
The only reasons to have a 50 though are to host large 5th wheel type guests or to run both ACs at once. A 30 is plenty for parking and occasional use, even on the larger Airstreams.
Airstream adventures and enhancements thread: Traveling with Tatay
Personal blog (photography, travel, woodworking, flyfishing, food): nryn.com
nryn is offline   Reply With Quote
Old 05-22-2021, 04:21 PM   #6
2019 30' Flying Cloud
Grass Lake , Michigan
When we built our pole barn for ours, we put in a 30a rated circuit with a 50A receptacle, to eliminate the need for adaptor on our 50A trailer. This saved a ton of $$ over running the heavy duty #6 wire for the 50A circuit. The only reason to have 50A is to run two AC’s. In a carport in your climate, it’s unlikely that you will need to run two AC units.
With the EZ starts on our AC’s, we can run both on a 30A circuit.
oldenavy is offline   Reply With Quote
Old 05-22-2021, 04:25 PM   #7
Thank you all, this is very helpful!
Old 05-23-2021, 09:49 AM   #8
Charleston , South Carolina
I ran a 30 amp and a 20 amp. I can run tools or a heater off the 20 whilst keeping the van plugged in.
Instagram @coasttocoastphotoatl
coasttocoast is offline   Reply With Quote
Old 05-23-2021, 09:56 AM   #9
2020 30' Classic
2015 25' Flying Cloud
Blue Ridge , Georgia
30Amp vs 50Amp
Lots of good replies. There are U-Tube video's on wiring RV Recepticals. If you don't require along run of #6 wire I would go with 50Amp and just use adapters to hook up for 30amp service or 15amp. These are adapters that most of us carry in case needed.
I wired my 30amp from the circuit box in my basement to the outside of the house maybe 25' of wire for a 25' FC then two years latter bought a 30' AS with twin AC's wishing I had wired 50amp to begin with.
Gleverett is offline   Reply With Quote
Old 05-23-2021, 10:05 AM   #10
DaveG's Avatar
Here and There , West Coast
Some more thoughts: Best to match wire, breaker, and receptacle ratings. Factor in voltage drop for distance. GFCI breaker. Couple of bigger than minimum size conduits buried 24" deep is a great idea. Dedicated trailer circuit plus general purpose recept another great idea. Will you want an outdoor light? And, price of wire is out of sight right now. Prepare for a price shock! (Forgive the pun )
DaveG is offline   Reply With Quote
Old 05-23-2021, 10:21 AM   #11
DaveG's Avatar
Smile
My mention of GFCI is just a suggestion for the RV circuit. Code does not require. Debate has been going on for years regarding this and although a good idea from an electrical standpoint it would be a major expense to upgrade older installations and expensive for new ones so lots of push back from the industry. The argument is, does the circuit come under feeder, or branch requirements. If you are doing your own I suggested GFCI only as an upgrade idea.
Old 05-23-2021, 04:19 PM   #12
1964 30' Sovereign
Ione , CA
Do separate ones side by side. Do not put it in/on the floor - eventually you'll have a leak in something (roofing, trailer tank, gas can tipping over, etc.) and a floor receptacle will cause trouble. Wall or column mount it up at least 18" off the floor.
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 05-23-2021, 05:59 PM   #13
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
In our shop..we installed a 50 amp box..I use an adapter if a 30ampis needed
Progressive Dynamics 50 Amp 240vac Distribution Panel W/ 15 Amp Outlet Scotty508 Airstream Classifieds 0 12-16-2019 12:13 PM
50 Amp to 30 Amp adapter to 20 Amp outlet?? Reynolds Our Community 15 08-04-2017 07:16 AM
30 amp cord to 50 amp outlet. urnmor Batteries, Univolts, Converters & Inverters 20 10-21-2011 12:55 PM
30 amp plug into 50 amp welder outlet? flyfish Electrical - Systems, Generators, Batteries & Solar 17 07-06-2011 03:56 PM
