Old 11-22-2022, 06:43 PM   #1
Anchorage , Alaska
Heat with over winter storage ?
Not sure if there is a better sub forum for this question.
I’m pulling wires, last step before I reinstall interior skins. I’ve re-insulated with styro insulation rather than fiberglass. No cabinetry or appliances, so there is a big opening in the outer skin where the water heater used to be, but other than that, the outer skin & windows are tight.
Just went in to refresh my memory, on were I left off this last fall, and saw frost on the ceiling, and occasional drips.
At some point I’ll have cabinetry & upholstery to take care of. Do I need to keep heat in the AS over the winter ? Does the ~2’x2’ opening contribute to the moisture inside so will not have issues once completed?
Aktundra is offline   Reply With Quote
Shore power over winter storage Jim9640 Batteries, Univolts, Converters & Inverters 0 09-10-2021 01:44 AM
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 09:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Any Special Storage Requirements for ZipDee Awning over Winter wabislander Awnings 10 07-11-2015 06:49 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
