Originally Posted by hatterascal
I can’t find my low point drains! My manual (2022 Caravel 20fb) shows them as valves on the underside. Nope. I have a red tube and white tube sticking out. Could that be them? Do they just empty with gravity?
It’s likely the valves are located close above that tubing inside the trailer, they will drain by gravity and you can hurry along emptying most of the on-board water tank with assistance from the water pump. Close the galley and bathroom water fixtures to avoid pumping water into your waste tanks. I am assuming you want to winterize.
