08-01-2020, 06:42 PM
#21
2019 30' Flying Cloud
Grass Lake
, Michigan
We used wood blocks for many years. When we bought our AS, the dealer 'threw in' a set of the anderson 'comma style' levelers with the sale. We thought it was kind-of gimmicky until we tried them. Now we love them, very precise control & super easy to use. Read the comments about them breaking but we've had no issues on a 30' trailer in ~2.5 years of use. They're certainly more reliable than the hydraulic auto-level systems in many SOB trailers.
08-02-2020, 12:12 AM
#22
2020 25' Globetrotter
Santa Rosa
I have a couple of carry bags of the lego style blocks (Lynx Levelers) so I have enough for any eventuality. They have worked well and offer good flexibility as you can build them both tall and wide if necessary. With the cap pieces they are also useful for placing under the jack and stabilizers so the pads don't have to rest in the dirt or occasional muck.
The Anderson style levelers look clever and I've been tempted to get a pair. But I've hesitated because of the breakage complaints which seem a little too common.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
08-02-2020, 04:40 AM
#23
2014 25' FB Flying Cloud
Cincinnati
, Ohio
What app?
Originally Posted by SeaLevel
Ramp style (roll up on them) levelers with a LevelMate Pro have been the best and easiest solution for us. Pull or back into the site, check level with the app, and if not level enough, it will show you how much you need to go up on either the driver or passenger side. If necessary, get out the ramps, then roll up on them while monitoring the app. Stop when level. Then level front to back using the app. For an overnight we sometimes only need to raise the front an inch or so, so we don't even unhook.
You'd want one ramp for each axle.
What app? Does it work for any type of leveling or just ramps?
08-02-2020, 04:44 AM
#24
Cincinnati
, Ohio
Originally Posted by ChuckFeldt
I cut a 8’ 2x10 in half and angle cut the ends. Connected them with a large gate hinge. If level can de achieved with 1.75” I lay it out If more needed I leave folded. The hinge bent a bit first use. But is a functional leveler.
Very clever!
08-02-2020, 05:14 AM
#25
2017 19' International
Tallahassee
I had a lego set, but the pieces cracked almost right away.
I have the comma thing, and it works great. Used it once, and keep it as a backup. Was a bit too fiddly for me.
Then made some wood blocks (painted a handsome green).
The wood blocks are so simple to use. Ours is a Bambi, which means don't need a lot, with just one tire to work on, so weight is not a concern.
If I get my hands on some cedar, I may make a lighter set.
08-02-2020, 06:36 AM
#26
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina
, North Carolina
Originally Posted by ROBERT CROSS
17 Seasons with my hinged board with 'block stops' using the lego's.... SFSG. (a favorite spot is soft sand)
Plus the board works well if it rains.
The '63 Frantic Banana reefer was very sensitive to level, Cloudsplitter not so much.
It's a question of SWMBO being 'level'. She's not happy, 'til I'm not happy.
Bob:
Please tell me about your wheels. Stainless? Brand, Size. Are you using 16inch?
Thanks.
08-02-2020, 06:45 AM
#27
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by Silverbee
Bob:
Thanks.
Stock OEM Alcoa 15"...no clear coat. Just polish when needed.
08-02-2020, 07:16 AM
#28
2016 25' Flying Cloud
Jupiter
The app that's part of the LevelMate Pro solution. You need the LevelMate unit installed and configured for your RV, and then the app communicates to it via Bluetooth. It doesn't matter whether you use wood, blocks or a ramp. It just tells you how much you need to raise a side, and raise/lower the front to get level.
https://www.amazon.com/LogicBlue-Tec...72&sr=8-2&th=1
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
08-02-2020, 08:18 AM
#29
2018 28' International
Fayetteville
, Georgia
I use one or two composite deck boards, as needed. Most of our sites are fairly level, so usually only need one. The composite boards are easy to clean and don’t rot or warp.
brick
2018 International Serenity
Cute wife...
08-02-2020, 05:23 PM
#30
2015 25' FB Flying Cloud
Barnstable
, Massachusetts
Anderson type levelers and nothing else. There is no simpler, precise way to level.
08-02-2020, 05:33 PM
#31
2018 22' Sport
Salem
, OR
Leveling
The square plastic levelers have worked fine with our 22 foot Sport Bambi; after 20,000 miles a few looked like they needed replacing and so I did. I wrapped our "spare" entry step fabric cover around four of the old ones (2 side-by-side stacks of 2) which makes a nice foot rest for sitting on the "geriatric height" toilet!
08-03-2020, 05:17 AM
#32
Tallahassee
What's up with the hinge? I'm having a hard time visualizing this.
Can you post a pix?
08-04-2020, 10:28 AM
#33
Wolfwhistle
Margaritaville
, Banana Republic
The beauty or the Levelmate Pro is sometimes it is possible to stay a little left or right further forward or back and stop at a point when level or close to level. The only CON I have found it sometimes the app is flaky. i've have to remove and reinstall to get it talking again. I think on the newer models this has been addressed
WW
Is taking it all with you, really getting away from it all?
08-04-2020, 12:00 PM
#34
Tampa
I use the legos and like them. Recently I added the Level Mat Pro so I could find the best spot to stop, and how many blocks I'd need.
The legos come in a bag of 10, it takes six blocks to make two pyramids two blocks high. If you need to go three high, you need a second set. (so four squares never got used! )
Somewhere I have a few lengths of wood I'd use instead.
The true test of "level" is if the bathroom door stays where I leave it and the microwave drawer isn't always trying to close.
08-05-2020, 09:40 AM
#35
Tampa
I'm thinking the comma style is great IF you have a spotter. It's critical where you stop. As a solo driver, putting the truck in park allows it to roll a bit, negating the advantage of the comma.
08-05-2020, 09:49 AM
#36
2018 30' Flying Cloud
Fort Myers
Anderson Levelers with Level Mate app
Red Andersons are great with the level mate pro. I've been using them for 3 years and never had them break. I get the trailer level, put truck in park and engage parking brake to eliminate moving the trailer off level.
08-05-2020, 10:24 AM
#37
2011 31' Classic
Baton Rouge
, Louisiana
I have both the legos and just purchased a set of Anderson (red, commas). I like the Anderson system (a lot). I travel alone and simply back on to them watching the level bubble mounted on the propane cover (close enough for me). I also tested (in my driveway) cascading 2 commas together to lift the tire high enough to change a flat on the same side. It worked like a champ. No more jacking...unless you have 2 flats at one time on the same side.
08-05-2020, 10:46 AM
#38
2013 27' FB International
2016 27' International
2021 30' Globetrotter
Nashville
, TN
Commas!
I know this doesn't answer your question completely, but I hope it might be useful to someone. We have used a couple different types of the blocks and this time around we purchased the commas, the heavy black ones (I can't remember the brand name at the moment, not Anderson). They slipped out from under the tires the first use, but I stuck some of the sticky stair tread on the bottom, the very gritty material, and it works very well. The commas are a breeze! I was able to level the AS without my husband in one try. I would not have been able to do that with the blocks!
#39
2016 25' International
Morgan Hill
What he said.
Carrying wood (weight)? Adding removing lego blocks. Back and forth...is it level yet? add another one...too high....take it out...too low...pull forward...pull back.
Comma style...slowly pull on to it..check with partner when level or stop the pulling and get out and look for yourself. Another inch should do it. Done
And why would you need 3? Only leveling on one side...and only have 2 axles (unless you have 3...then get 3)
Now lets talk about oil....no wait religion...no politics...nah TVs
08-05-2020, 10:51 AM
#40
Nashville
, TN
Commas!
I know this doesn't answer your question completely, but I hope it might be useful to someone. We have used a couple different types of the blocks and this time around we purchased the commas, the heavy black ones by Beech Lane. They slipped out from under the tires the first use, but I stuck some of the sticky stair tread on the bottom, the very gritty material, and it works very well. The commas are a breeze! I was able to level the AS without my husband in one try. I would not have been able to do that with the blocks!
