Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 03-21-2012, 05:38 PM   #1
1998 35' Cutter Diesel Bus w/slide
Laud by the sea , Florida
I need some parts for my '98 35' Cutter!
Hi all,
New to this, so im gonna have a million questions;
Where do I get entry door weatherstrip?
I need a rear upper tail light lens, where???
Thank you!
mfancher is offline   Reply With Quote
Old 03-21-2012, 06:12 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Welcome to the Air Forums.
Your tail lamp is not the same as my Clipper which is Hella. I believe yours is readily available at any auto jobber. Just take your lens there to buy or order. There should be a name and # on the lens that you can use Goggle to find the source.
The weather strip will probably be available also from the auto jobber (NAPA). Take a sample with you.
Give us some pictures of your unit.
Dave
Originally Posted by mfancher View Post
Hi all,
Thank you!
masseyfarm is offline   Reply With Quote
Classic Motorhome Parts and Salvage streamquest Classic Motorhomes 111 09-21-2016 10:36 PM
My next project is a basket case... InsideOut Vintage Kin 142 10-19-2013 09:18 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
I need some parts for my '98 35' Cutter! mfancher Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-21-2012 06:12 PM
