-   -   I need some parts for my '98 35' Cutter! (https://www.airforums.com/forums/f456/i-need-some-parts-for-my-98-35-cutter-88996.html)
mfancher 03-21-2012 05:38 PM
Hi all,
New to this, so im gonna have a million questions;
Where do I get entry door weatherstrip?
I need a rear upper tail light lens, where???
Thank you!
masseyfarm 03-21-2012 06:12 PM
Welcome to the Air Forums. :)
Your tail lamp is not the same as my Clipper which is Hella. I believe yours is readily available at any auto jobber. Just take your lens there to buy or order. There should be a name and # on the lens that you can use Goggle to find the source.
The weather strip will probably be available also from the auto jobber (NAPA). Take a sample with you.
Give us some pictures of your unit.
Dave
Originally Posted by mfancher (Post 1123236)
Hi all,
Thank you!
