Old 04-18-2021, 06:32 AM   #1
Bambii's Avatar
2016 25' International
Atlanta , Georgia
Dripping from edge pan?
We’ve got some water dripping from the edge of the pan underneath the back of our trailer. I just noticed this early in the morning. The airstream is parked so that the jack is higher than the back. Any chance this could just be condensation? What are other clues of a leak? I want to take it in somewhere but it will be awhile. Any advice on how to investigate? She’s a 2016 International Signature 25FB and the love of my life.
ID:	393409   Click image for larger version
Bambii is offline   Reply With Quote
Old 04-18-2021, 08:58 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Well...Usually the best indication that you have a leak is water dripping... Then again, maybe it could be condensation. I suppose the way to tell the difference would be to wait until later in the day, when condensation should have evaporated, and check to see if you still have a drip. Has it rained recently? If so, maybe you just have some water trapped in the belly, and it has to drain out.
If you have a consistent drip, then there are a few things you can do to troubleshoot:
Are you attached to shore water? If so, disconnect and wait to see if your drip continues. If it stops, at least this eliminates a leak from the fresh water tank.
Drain your black and grey water tanks, then do not run any additional water into them, and wait to see if you still have a drip. If it stops, then this suggests a leak from the grey or black water system rather than the fresh water system.
Open up all of the cabinetry and look for water dripping/pooling underneath.
Check any exterior exposed plumbing/tanks/dump valves.
Good luck!
Old 04-20-2021, 04:51 PM   #3
2006 25' Safari SS SE
Alfred , Maine
Dripping water
We had a similar problem and thought it was a leaking tank also. Dropped the pan and found it full of water. Discovered the problem was water getting into the belly between the bumper and trailer. Sealed it and problem solved. I think there is a thread someplace here about this. In talking around common problem. Some people have issues with floors rotting where the water is getting in. Our floor was wet but it dried out once the pan was dropped. Drove us crazy because it would only leak sometimes. As it turned out it depended on the pitch of the trailer.
Airdreamer2 is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Water dripping from back roadside belly pan airforus Plumbing - Systems & Fixtures 4 08-06-2018 04:51 AM
Pan or no pan bigal1437 Furnaces, Heaters, Fireplaces & Air Conditioning 9 08-20-2017 08:54 AM
Shower Pan Drip Edge mingle51 General Repair Forum 1 05-25-2016 07:09 AM
Penguin A/C dripping inside Janssvt Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-25-2004 08:22 PM
