01-06-2017, 10:29 AM
#21
2001 16' Bambi
2013 23' International
Piedmont Region
, North Carolina
A Fluke Batwing Antenna ??
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'18 F150 Lariat maxtow --- Liz
01-06-2017, 10:32 AM
#22
2005 30' Safari
Montgomery
Is it practical to replace the entire antenna assembly with the King Jack that doesn't raise/lower? That was my plan until I saw this thread. FWIW--I'm dealing with a new-to-me AS that needs new sealant everywhere and has been a little abused over the years.
01-06-2017, 11:07 AM
#23
1973 Argosy 24
hartselle
, Alabama
It's very practical, and one of my favorite uogrades. I no longer stop 5 miles after breaking camp to make sure I remembered to lower my antenna. The profile of the antenna doesn't bother me at all.
01-06-2017, 12:13 PM
#24
2000 25' Safari
1999 34' Excella
Davidson County
, NC Highlands County, FL
Originally Posted by dznf0g
It would be interesting for a side by side comparison at a CG, the the batwing with the added "wingman" UHF elements works very well among the units I have used in the past.
<< snip>>
This is a side by side comparison. Before and after is the same antenna with and without a Wingman. It is parked in the exact same location, have not moved since October.
Originally Posted by A W Warn
<< snip>>
Today I am in my Excella near Sebring Florida. My Excella has the original bat wing antenna. I added the Wingman in December. The location I am at is almost level (within 100') of Miami, Orlando, Tampa, Ft Myers, and Palm Beach. Before the Wingman it would only pickup Tampa and sometimes Orlando stations, both 75 miles away, but the picture was interment from Orlando. Since I added the Wingman I pickup clear pictures from all of the locations mentioned above. However, the picture from Orlando is not the quality of the others. There is a range of hills, the Lake Wales Ridge which is about 200' higher in elevation, that is in a direct line between the transmitter and receiver. Miami is about 140 miles away at 6' above seal level. I am parked at ~80' above sea level. The picture quality from Miami & Palm Beach is better than Orlando.
The only gripe I have with the bat wing and the wingman is that it is directional. It's a PITA when I'm in bed watching and have to get up to rotate the antenna when I change channels. I would much rather have an antenna that receives signals from all directions.
Alan
01-06-2017, 12:20 PM
#25
Oswego
I think you misunderstood. I was interested in a comparison between the batwing w/wingman against the King Jack. I am fully aware of the improvement of the batwing when adding the wingman. I added mine when they first came out. It's been 6 years, so my recollection of the exact numbers is fuzzy, but I went from 20 something channels to over 40 with the AS sitting in my driveway in a metro area. Of course, many channels are in Spanish, but the increase of signals was impressive.
Edit: Wait, actually, it has been way more than 6 years. I took the wingman off my SOB before trading for the AS...so I have had it for a LOOOOng time. Comparison was done on the AS though, before and after installing the used Wingman on the AS.
-Rich-
01-06-2017, 12:31 PM
#26
2000 25' Safari
1999 34' Excella
Davidson County
I think you misunderstood. << snip>>
Yes I did. Sorry!
Alan
01-06-2017, 02:59 PM
#27
Oswego
Alan, I too would like the omni-directional capability....but that's where I want a head to head comparison. I have read of so many complaints of the omni's, that I am unwilling to risk trying one.
-Rich-
01-06-2017, 04:13 PM
#28
2007 34' Classic S/O
Hillsboro
TV antennas for Airstream
When Winegard brought out the Wingman add on for the batwing antenna, it was in anticipation of the switch to digital broadcasting and that all TV channels would be on UHF. The big, flat, rectangular aluminum loop on the batwing antenna is the active element if the antenna anc is made for the VHF band. Addition of the Wingman adds a small bit of gain to the antenna's UHF sensitivity but in the end, not nearly as good as an antenna designed to receive UHF frequencies. Now Winegard has the Rayzar antenna for today's digital TV and it works well according to users. I'm very happy with my King Jack and have never minded rotating the antenna. It can be a pain however when 2 stations are at right angles from my location.
John Green, Hillsboro, TX
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 & ARC member W9CJX
01-06-2017, 04:17 PM
#29
Northeastern
, Kentucky
TV reception - finally!
Are the winegard rayzar and King considered comparable then? With next best being the batwing with sensar wingman?
01-07-2017, 09:07 AM
#30
2013 25' Flying Cloud
Wheaton
No free lunch. Omni directional antennas are less sensitive than directional antennas. Can't change the laws of physics.
Greg
01-07-2017, 09:34 AM
#31
Oswego
Greg
Exactly. And why I won't change out unless I have to. But, there are smaller profile directional ones. Would love to compare them with the wingman setup.
-Rich-
01-07-2017, 10:08 AM
#32
2008 34' Classic S/O
lanark
, Ontario
I picked up a King replacement for my crank up unit. Was going to install it but after reading the instructions, I realised that I needed to increase the size of the hole in the roof! Didn't sign on for that so back it went. Will pick up a King replaement head for the Wingman when I get home and try that with the existing Jack. Looks simple and pretty cheap. No need to try it here as no TV in Baja
Thanks for the info
Pete
Pete Crook
"Put it all behind you!"
S/OS#88
WBCCI # 8160
01-07-2017, 10:16 AM
#33
1973 Argosy 24
hartselle
, Alabama
Thanks for the info
Pete
I didn't have to enlarge the hole size to mount my king jack. Think I remember reading that too, but it was not required in my set up.
01-08-2017, 12:26 AM
#34
2007 22' International CCD
Corona
The usual saw about omnidirectional antennas is that they work equally badly in all directions....
01-08-2017, 10:41 AM
#35
Hillsboro
King Jack head replacement
I kept the crank raise/lower part of the original antenna. Raise the old antenna and rotate it 90 degrees CCW. Now crank it down to the stowed position. The antenna will now be about right over the door. This works for an AS with a door toward the front and not the rear. Now it's easy to remove the coax and 2 pins with "E" clips and lift off the batwing antenna. Put the Jack antenna on top of the bracket, replace the pins and install the clips, reconnect the coax and you're done. Check your work and push the red/green button on the TV wall plate and check the red LED on the bottom of the Jack head unit. If it's on, you did it right. Now crank up the lift mechanism, rotate it back to the stow position and crank it down. Enjoy better TV reception. Even the little height of the lift may be enough to help with weak signals.
01-08-2017, 11:51 AM
#36
1997 25' Safari
Montgomery
, Alabama
JW
I thought I was a genius when I rotated the antenna and attached the new head as you described...BUT when I tried to stow it the head wouldn't nest in the little cradle still attached to the roof and the up/down arm wouldn't fall into the little "spikes" on the base plate....did I put it on backwards??
Sorry no picture (didn't want to document my ineptitude)
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
01-09-2017, 09:32 AM
#37
Hillsboro
Jack antenna mount
Al/Pat,
You may have it 180 degrees off but not sure. I had a similar clearance issue with the antenna cradle and it's a close fit anyway. You could try turning it around to see if it stows properly. I'm guessing that AS doesn't always put the cradle in exactly same location on the roof because the Winegard antenna head has a smaller footprint . If you do change it, please comment back on this thread.
01-09-2017, 10:14 AM
#38
2007 30' Classic S/O
durango
Where is the wall jack to replace for the King Jack?
Originally Posted by jwgreen
The Winegard batwing antenna was designed for VHF frequencies when TV was analog. Now that it's digital, all over-the-air television broadcasts are on UHF frequencies, like channel 14-83 on the old analog system. Antenna size and design is based on being efficient at collecting enough signal for a good picture. The King Jack antenna is smaller because it is designed for UHF signals only. The wall TV outlet in the AS (green or red light) used with the Winegard is retained for the King Jack. It feeds the DC voltage over the coax to the antenna to power the amplifier in the "head" unit or external part. There is a red LED on the bottom of my Jack that shows the presence of DC power. It's worked great for 5 years. It is directional, just like the Winegard, so rotate it to get a picture you can watch. Weak signals will result in "pixelation" or blank spots in the picture. In virtually all cases, the King Jack antenna will outperform a Winegard batwing antenna.
I am replacing my old original antenna (2007-Classic-31") with a new HD King Jack antenna. Where is the wall jack that I need to remove (is there low voltage power there) so I can replace with the new low voltage powered wall jack that is required for the King Jack antenna?
01-10-2017, 09:13 AM
#39
Hillsboro
Are you sure you need to replace the wall jack?
If your 2007 AS was built with a wall jack for TV, it has a push on/push off button to turn on the 12 VDC to the amplifier in the original antenna, most likely the Winegard "batwing" antenna. This feed is totally compatible with the King Jack antenna amplifier, at least it was on my 2007 AS. The wall jack also has a type F standard TV cable outlet and a automotive type 12 VDC receptacle built in to the face plate. It would be very unusual if you don't have one in your trailer. Both antennas require the same voltage feed over the coax cable to operate properly. If your wall outlet DOES NOT have the push on/push off switch with a green LED indicating it's on, then you will need to install a different wall jack and provide the 12 VDC feed into the jack.
01-12-2017, 04:04 PM
#40
durango
Is this wall jack located by the existing TV? Thanks. Jim
