Old 11-29-2021, 09:07 PM   #1
2007 30' Classic S/O
2013 28' International
2006 25' International CCD
seaford , Delaware
king jack low mount
b ought new king jack 8500 with meter and base.current bat wing sits off center towards awning.current antenna does not vertical with curbside lean.will need to figure how to set base level for proper operation.any suggestions.?
claymanjack is offline   Reply With Quote
Old 11-30-2021, 02:20 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you're mounting the new antenna in the same position as the old one, can you make a wedge block to put under it? Not sure of what tools you have available, but my first approach would be to get a block of pvc about 3/4" thick and large enough to cover the footprint of the new antenna, and then work it with a belt sander until the bottom profile matched the contour of the roof. Depending on the curve of your roof where it's going, you might even need a block 1" thick.
If you have a plastic supply house in your city you should be able to get some pvc solid foam board scraps for not much money which you can use for this. The stuff is easy to work with.
Once the wedge block was shaped correctly, a bit of sealant top & bottom of it and screw the new antenna in place.
Richard
11018
richard5933 is offline   Reply With Quote
Winegard Rayzar z1. Vs. King Magic roof mount antena GatorDave Electronics & Connectivity 1 12-12-2017 09:27 AM
2017 Flying Cloud 30 ' Hub Mount / Stud Mount question twolanehwy General Repair Forum 3 09-24-2017 03:03 PM
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 05:31 PM
Flush Mount or Surface Mount Zac&Kristin Water Heaters, Filters & Pumps 10 01-13-2008 07:59 PM
