Originally Posted by richw46
For our 2006 model there is a jumper cable that needs to be connected for the rear TV to get a signal from the antenna. I think it needs to be disconnected if there is a cable connection on the outside. I never can remember but for the TV antenna the jumper needs to be in place and power to the booster must be on.
On my 2001 and now my 2002 trailers, that jumper was in the CATV cable between the outside connector and the switch plate. The design intent was to allow the use of that cable to bring in a signal from a satellite dish and connect one of the old satellite receivers (pre-HD days) in line. The satellite receiver would decode the satellite signals and remodulate them in the NTSC standard onto the cable. To watch the satellite one would turn off the antenna and the remodulated satellite signals would be routed to all TVs. Since digital TV came along, the remodulation process is much more complicated and expensive so the capability was dropped. Virtually no satellite receivers have an antenna output jack any more. It is simpler to put the digital signals on an HDMI cable.
On my trailers that jumper is required to watch cable TV at any TVs in the trailer. Antenna reception is not affected.
