Originally Posted by Wazbro
Factory electric water heater uses 11.6amps and AC uses about 14.6amps. That's 26 out of 30amps, add 3amps for the fridge and converter(if the batteries are fully charged) and you're out of power unless you have 50amp.
That Hotshot electric conversion is only 400watts instead of 1400watts for the factory version. Makes it better for older trailers.
Just remember the 11.6 is not a full time draw. We have a 31' classic('97WB) and we run everything electrically on 30amps no problem.
Kind of like your house-200amp service, but you don't use 200amps continuously.
