My 2014 Intl Serenity 27 has a battery setup that looks like the pic below. The large wing nut and the shaft it attaches to are badly rusted due to a leaky batt box which I think I've fixed. However, I don't know where/how to get a replacement nut and shaft (or what they're called). Battery hold down searches show me every different type of bracket, strap and bolt except the one I need. Assistance appreciated. 66coupe.
It's just threaded rod, stores like Home Depot, Lowes, ACE all carry it in various sizes and lengths.
Remove the one you have and match it at the store. Don't buy bare threaded rod, that will rust. Either go for the zinc plated or expensive stainless steel.
I expect you will have to cut the threaded rod to the right length.
Replace the big wing nut with a large washer and nut. It will do the same thing. If you want to get fancy you could make your own washer using a rectangular piece of plastic or like.
Until you find a real purpose made one, the threaded rod is 3/8", and you can use a large fender washer (I put a large rubber washer under mine), then a 3/8" wing nut. All found at Lowe's.
