Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 07-03-2018, 05:33 PM   #1
Herndon , Virginia
Replacement battery hold down wing nut and shaft
My 2014 Intl Serenity 27 has a battery setup that looks like the pic below. The large wing nut and the shaft it attaches to are badly rusted due to a leaky batt box which I think I've fixed. However, I don't know where/how to get a replacement nut and shaft (or what they're called). Battery hold down searches show me every different type of bracket, strap and bolt except the one I need. Assistance appreciated. 66coupe.
66coupe is offline   Reply With Quote
Old 07-11-2018, 08:29 PM   #2
2016 19' Flying Cloud
Portland , Oregon
It's just threaded rod, stores like Home Depot, Lowes, ACE all carry it in various sizes and lengths.
Remove the one you have and match it at the store. Don't buy bare threaded rod, that will rust. Either go for the zinc plated or expensive stainless steel.
I expect you will have to cut the threaded rod to the right length.
Replace the big wing nut with a large washer and nut. It will do the same thing. If you want to get fancy you could make your own washer using a rectangular piece of plastic or like.
Snowy is offline   Reply With Quote
Old 07-11-2018, 08:39 PM   #3
Portland , Oregon
I hope this works. Ignore the battery type, focus on the tie down rod in the picture.
http://www.airforums.com/forums/show....php?p=1940295
I bought that threaded rod from Home Depot as I needed a longer one to accommodate the 2x 6volt batteries.
You can see the rectangular "washer" I made too.
Old 07-11-2018, 10:10 PM   #4
Mollysdad's Avatar
Until you find a real purpose made one, the threaded rod is 3/8", and you can use a large fender washer (I put a large rubber washer under mine), then a 3/8" wing nut. All found at Lowe's.
Mollysdad is offline   Reply With Quote
Rear Hold down plate replacement Belegedhel Repairing/Replacing Floor &/or Frame 21 04-10-2021 08:50 AM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Battery box hold down strap Peter Housto Electrical - Systems, Generators, Batteries & Solar 1 06-06-2014 10:28 PM
Battery Hold-down Strap Shorting Against Positive Battery Post rel Sprinter and B-van Forum 3 08-13-2013 10:32 PM
Hold down plate, Panel replacement - pic heavy! crispyboy Ribs, Skins & Rivets 13 05-13-2013 09:41 AM
