Originally Posted by csb333
Hi,
Yes, I had my lithium upgrade completed in Jan 2021. Agree that it has been a big improvement but I still can’t leave Van without shore power for long periods as it will eventually drain and solar panels can’t keep up…this is even with master power off. I had 2x Battleborn lithium, Victron Monitor, new solar controller and upgraded Magnum controller. I can run overnight with fridge in power save and just heater on propane…no other draws. Next morning I need to start gen or drive van. So, better but not convinced I still don’t have some large drain on batteries.
Thanks sucks your still having issues. I just noticed that your signature states that you own a 2021 AI19. We have alot of 2021 owners on the AI19 FB page that has or had issues with power draws. I haven't plugged in my rig since the upgrade. My upgrade components and who installed the upgrade.
2x Battleborn heated lithium > AS in JC, OH
Victron Buck Boost replaced with lithium config > JC, OH (I had to tell them I needed the new configurations and they eventually switched it out.
Victron SmartShunt > me
Victron Smart Solar > me
Magnum controller upgrade > me
Magnum inverter/charger upgrade > wasn't completed because AS nor myself was aware it needed to be changed out. I still have the original one and not a big deal imo. The only disadvantage I have with this inverter/charger is that when connected to shore power, it won't change the house batteries until it reaches 12.9V or less. My house batteries never get that low due to the solar so all good. When I'm contacted to shore power, I don't need the batteries and when not contacted either the engine or solar will top off my batteries.
Now I just need to figure out how to wire the Victron Buck Boost purple wire to a wireless remote switch so when I plug in my GZ1500X, the power doesn't go upstream from the house batteries to the chassis battery. Once that's done, life is good.
