Old 02-03-2023, 12:25 PM   #1
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Seelevel II Tank Monitor power issues
The Seelevel II tank monitor is far more sensitive to "voltage ripple" than the other 12V appliances plugged on the 12V circuit. Voltage ripple is rapid voltage fluctuations, in this case most likely produced by the converter. Older converters were more prone to this than the newer models.
In my case when the trailer is on the road, it's the batteries supplying the 12V to the circuit and to the Seelevel. When setting up at a campsite if we plug into shorepower without disconnecting the batteries from the circuit by putting the battery disconnect switch in Store mode, more often than not the Seelevel display will "act up" with gibberish including an error condition such as Opn meaning the tank sensor(s) is not linked to the monitor panel.
On the other hand, when setting up at a site, if we first disconnect the batteries from the 12V circuit by setting the switch to Store mode and wait 15-30 minutes for the capacitors in the Seelevel monitor panel to empty before connecting to shorepower, then all is fine. Although this procedure works, it is a PIA.
From experience, and a call to the Seelevel manufacturer, it would seem that my monitor doesn't like the jolt the converter gives to the fully powered circuit when the batteries are connected. Reconnecting the batteries later by putting the Use/Store switch to Use mode doesn't affect the monitor. The solution would be to power the Seelevel from the batteries (which is the case when we boondock) and not the converter.
There doesn't seem to be a 12V fuse in the panel for the Seelevl? Is this correct?
Has anyone connected the Seelevel directly to the battery, or to the 12V bus? Would you put an inline fuse, or would you use one of the empty slots in the 12V fuse panel for the Seelevel?
Does anyone know how the Seelevel is wired to power?
Thanks for the input.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 02-03-2023, 12:54 PM   #2
Boxite's Avatar
2008 22' Safari
If you don’t have the manual for your trailer…you could start by pulling fuses one-by-one until you discover the one which disables it.
SeeLevel II tank monitor CraigCam Electronics & Connectivity 3 11-05-2020 04:35 PM
Seelevel II Tank monitor- reads 0 for Black tank waninae39 Electronics & Connectivity 2 08-07-2020 04:00 PM
SeeLevel 11 tank monitor issue Ravennaman Our Community 3 07-05-2020 03:15 PM
SeeLevel II Tank Monitor problem sburrw General Repair Forum 3 08-17-2018 04:35 PM
