Old 04-27-2017, 06:46 PM   #1
2016 27' Flying Cloud
Dade City , Florida
Added a Battery Cutoff and Rewired the Box
I added a battery cutoff and rewired the whole box.
  1. Got rid of the car battery lugs.
  2. Changed all cables to the heavier gauge.
  3. Added a common ground post.
  4. Parallel connections are long enough to go around instead of on top the caps.
  5. Using the switch as common positive post.
The original wiring was tight across the caps. I had to disconect them in order to check the water level.
Found everything at West Marine.
ID:	284280   Click image for larger version
Ernster is offline   Reply With Quote
Old 04-27-2017, 08:01 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
That looks great!!!! So much cleaner! I'm tempted!!!! [emoji3]
Old 04-27-2017, 08:09 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Thanks for posting. This is something that I've been wanting to do too. How did you cut the hole in the battery box?
I'm not sure I want to put the switch there, because it would be in the way if I wanted to add larger/taller batteries.
SeaLevel is offline   Reply With Quote
Old 04-27-2017, 08:14 PM   #4
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Use A bi-metal hole saw. Drill pilot hole first. 1/4 inch drill bit. Very clean and easy. Lowes and Home Depot sell them for around $15.
Troutboy
Troutboy is offline   Reply With Quote
Old 04-27-2017, 08:23 PM   #5
pt.reyesfan's Avatar
2016 30' Classic
Naperville , Illinois
Nice!
Ed
2016 Classic (with ProPride)
2016 Silverado 3500HD Diesel drw
1995 & 2004 Gary Fisher Hoo-Koo-e-Koo emergency vehicles
pt.reyesfan is offline   Reply With Quote
Old 04-27-2017, 08:53 PM   #6
2013 28' International
Bozeman , Montana
Nice upgrade. A battery disconnect should be standard from Airstream.
HeadWest is offline   Reply With Quote
Old 04-28-2017, 04:15 AM   #7
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
I did not think of using the side of the box for switch mounting!
I made a panel to hold the switch for my MH
The small "FIRE" switch next to the cutoff switch controls the House/Chassis battery solenoid. That allows me to join all 3 batteries manually if I need to.
WayneG is offline   Reply With Quote
Old 04-28-2017, 04:49 AM   #8
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
Ernster, I did the very same as part of my winter servicing. The battery box was a tangled mess from the factory. I chose to mount the switch and the common post exterior to the battery box. I placed the switch on the negative side with the positive all going to a common post in a junction box. Heavier gauge wire on the connections too.
Here is my question. I may be missing this in your picture but it looks like your switch is wired between your batteries and not between the batteries and your trailer. Shouldn't the battery at the bottom in the third photo be directly connected in parallel to the upper battery? The switch would disconnect both batteries instead of just the parallel connection.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn
2023 F150 XLT
FishByFly is offline   Reply With Quote
Old 04-28-2017, 04:56 AM   #9
Chelsea , Maine
Look closer, he has it right. The red wires on the right run close together but the switch is not breaking the parallel wire.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 04-28-2017, 05:45 AM   #10
FishByFly's Avatar
Yes. I now see the positive parallel wire running below. I kept looking at this photo trying to figure that routing. Thanks. These improvement sure "clean up" the standard wiring.
FishByFly
2023 F150 XLT
Old 04-28-2017, 06:14 AM   #11
centennialman's Avatar
2016 23' International
Centennial , Colorado
This looks great! I think I will do it!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-28-2017, 11:53 AM   #12
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
What gage did you use and changing from battery post, did you solider the new connectors to the current cable?
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 04-28-2017, 01:51 PM   #13
2004 28' International CCD
Cocoa , Florida
That's AWSOME!!! I've been wanting to do that for years, now I must....
Great job!!
Bhkh226 is offline   Reply With Quote
Old 04-28-2017, 02:22 PM   #14
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
That's a good looking solution. I presume you have a relatively late model trailer that has one of the pseudo-disconnect switches inside the trailer. If so, I'm under the impression they disconnect most things from 12V but leave some parasitic loads for safety related items. The type of single-pole, single-throw (I think) switch you installed will do the job to really disconnect the entire battery bank.
We added a switch very much like yours in our Airstream B190 van. I was surprised that van did not come with a disconnect switch. Our 1992 Classic trailer has a switch very similar to yours and it came from the factory.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 04-28-2017, 05:46 PM   #15
Dade City , Florida
It's the angle of the photo. I have the two batteries in parallel and one cable to switch.
Old 04-28-2017, 05:52 PM   #16
Dade City , Florida
Changed everything to 4 AWG. I used a hammer style crimping tool with a 2lb mallet. Two hard hits and it was done.
All of the wire and lugs are marine grade.
Old 04-28-2017, 06:24 PM   #17
Dade City , Florida
Hole saw from the inside. That was the hardest part of the project. It's difficult to get pressure directly behind the drill.
The switch I bought can be fully surface mounted on the outside. I thought it looked better the way I did it.
Old 04-28-2017, 06:30 PM   #18
Dade City , Florida
Oh yea........
The total cost for for the job was about $75. Using marine grade components drove up the cost. You can do it cheaper by using automotive components.
Old 04-28-2017, 06:35 PM   #19
dames7's Avatar
GILBERT , Arizona
Thanks.
David & Nancy Ames
2015 FC 25' RB
Old 04-28-2017, 06:42 PM   #20
PKI
PKI's Avatar
Walnut Creek , California
Very nice job. Certainly a must do if the coach spends time in storage. Our shutoff switch ended up next to the shell in the triangle section of the frame to the curb side of the OP's switch. It's protected there and does not take up space in the box. However, we have a terminal block located where the OP's switch is and it does take some space that might be used if we went bigger on the batteries. Upgrading the cable size is a great addition to the install. Pat
battery boxes, battery disconnect
Does this breaker box need to be rewired? grndslm Electrical - Systems, Generators, Batteries & Solar 12 11-14-2021 09:32 AM
Battery Cutoff Swithes noiva Mechanics Corner - Engines, Transmission & More... 19 05-28-2018 09:27 AM
Battery cutoff switch contradiction - 2007 Classic dznf0g 2006 - 2010 Classic (all lengths) 0 09-29-2010 08:10 PM
Battery Cutoff Switch Silverbee Electrical - Systems, Generators, Batteries & Solar 16 09-13-2010 06:00 PM
