Curious to learn what (if any) other Air Forum Members, and Airstream owners have done in terms of the semi-permanent mounting of dual Honda EU2200is gen-sets on the front A-frame of their Airstreams.
I am aware of the LowPro "puck-lock" type lock-down trays but apparently they are too far behind in production with something like a two-year waitlist now so I plan to move ahead with my own or a similar design of others.
I am wanting to fabricate (or have fabricated) some means of mounting a pair of the generators on the front of my Classic M30 that will afford the convenience of transporting them and use while boondocking or otherwise when desiring to do so. I also need to accommodate clearance of my WD hitch vertical spring bar jacks (ProPride 3P) as well as want to maintain access to the battery box located in-between the A-frame. As well, my design will not impede the turning radius between my TV and the TT.
At present I am working with a fabricator on an idea of a design I came up with as shown in the drawing below. We are only in the initial stages now of the fabrication design.
My design is based upon placement of the mounting base by direct attachment to the sides of the trailer A-Frame in a manner that would both support the weight of the generators (46 lbs. ea) while enabling them to be locked into place (anti-theft) using typical hitch bar coupling locks as well as the "puck" lock design.
Noteworthy to add, I have a full on Vectron/Lifepro lithium solar system installed on/in my Classic M30 whereas the lithium batteries (of which replaced the pair of 66 lbs. OEM batteries normally located in the forward A-frame battery box,, 132 lbs. total) have been relocated to underneath the dining booth inside my Classic. Hence, the added weight of the generators (46 lbs each or 92 combined) and mounts (wgt. TBD) on the front A-frame are not expected to result in added or excessive weight given the front OEM battery box is now empty (and used solely to store my propane hoses for the dual Honda both of which have been converted to propane fuel only).
Again, curious to what others wanting to (or having done) may look like.
Below is the work-up sketches of the design I am working on with a fabricator and should this materialize as the actual design, I will be happy to share the final specifications and drawings of with others having similar interest or desire.
Attachment 393357
